JamesUK
Better Window Switch?
Hi all, so today my passenger window decided not to work, most likely a bad switch. Now before I go and put in a identical replacement has anyone had luck with using a different (better) designed switch... Say the 924/4/68 type?
Thanks in advance Pelican's!
Old 03-23-2017, 10:21 PM
Member 911 Anonymous
DRACO A5OG's Avatar
OEM Porsche, they use copper connectors as opposed to the tin clad ones from China. The only thing, it is not shiny smooth like the original OEM.
'85 Carrera Targa
PCA/POC
Old 03-23-2017, 11:57 PM
esample's Avatar
What he said. I just had the identical proble. Always go OEM.
Black Widow
Blk on Blk '86 911
"...the secret to Porsche: we do things others cannot"
Old 03-24-2017, 06:03 AM
JamesUK
I have OEM. To me it seems the design is not robust. By that I mean the toggle switch itself, the movement that is there other than up and down. I noticed that 924/44/68 cars use a simple rocker switch. Seems to me that would not have the same issues as our 911 switch. Has anyone replaced the 911 switch with a different unit completely?
Old 03-24-2017, 09:21 AM
Here:
Amazingly, someone with the same name posted the same question.
Anyone use a diffrent design Window switch?
Old 03-24-2017, 10:55 AM
schoward's Avatar
They all pretty much suck. I have old school shiny genuine Porsche ones that fell apart just like any others. I have found the oem/German ones are about as good as you get for a reasonable price , and not a bad idea to maintain a spare one in your parts bin as when they go bad it is frustrating to delay a road trip because of a simple <$20 part that may be unavailable locally. Last time I had one go bad even my local dealer had to get it (not in stock). They are so cheap - get a spare.
Scott
1981 911SC Targa - Platinum Metallic
Old 03-24-2017, 11:46 AM
Since the day mine got stuck at a toll booth in a down pour, I have always had a spare in the glove box. In 16 years of ownership I have replace 3.
JUAN
'80SC Targa
Old 03-24-2017, 11:50 AM
Administrator
Dmitry at Pelican Parts's Avatar
In case you need any guide on the troubleshooting and install process, check out the link below to a DIY tech article. Lastly, if you're looking for an alternative to the OEM switch, give us a call at 888-280-7799 and one of our Porsche parts specialists may be able to give you some suggestions. Best of luck!
Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
-Dmitry
Old 03-24-2017, 12:29 PM
Eng-o-neer
Tremelune's Avatar
It is a flawed design, including the originals from Porsche.
That said, they last years. Sometimes many years. I've replaced several, but never the same one twice.
When I get around to interior work, I plan to rewire mine to two standard relays and momentary toggle switches on the dash. Simpler, cheaper, better.
Old 03-24-2017, 02:18 PM
Be careful with the non Porsche switches. I installed one of those I got from Pelican and it lasted just a month or so before the toggle hinge broke and allows the switch to move around instead of rotate and causes the switch to malfunction at times. What appears to cause the hinge to break is when raising the window your finger slips off the switch and it snaps back to center. Yes it was much cheaper than the Porsche switch but it definitely did not last very long.
Old 03-26-2017, 08:17 PM
Bill Douglas's Avatar
Mine have lasted about 37 years so they can't be too bad.
Old 03-26-2017, 11:15 PM
