911 pedal cluster install help
In the workshop manual there is a rubber stop/sleeve part no. 901-423-193-00. I don't see it in the exploded view of the pedal cluster illustrated above. Where does this rubber piece get installed?
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Pedal Cluster Rebuild | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 02-13-2017, 11:06 AM
Exploded view here: http://www.pelicanparts.com/More_Info/901-423-193-00-OEM&SuperCat=Y&SVSVSI=801.htm
- Casey
The question still remains, where does this rubber piece get installed?
gary
Old 02-14-2017, 02:15 AM
If you look at the diagram that Casey posted, it goes on the angle piece on the side of the pedal housing just to the left of the rubber part in the diagram- it ends up oval shaped when installed.
Rutager West
Old 02-14-2017, 03:12 AM
Here's another thread that you should be able to see the stop on the metal part.
Rebuilt Pedal Cluster
Rutager West
Old 02-14-2017, 03:16 AM
I believe it goes on the brake petal rest.
Bruce
Old 02-14-2017, 03:39 AM
proffighter's Avatar
There are two rubber pieces, choose which one you mean:
Roland
930 Turbo '81 Too many modifications to list
Old 02-14-2017, 04:03 AM
Great posts from everybody. Not retaining the round shape was the clue. Thanks
gary
Old 02-14-2017, 04:42 AM
