Send a message via MSN to scott_rogers
Help with VDO Guage
The other day my odometer stopped working and I just assumed it had the infamous broken gear issue. So I ordered the gear from Pelican and started the project tonight.
Upon inspection the gear appears to be fine. I suspect it was replaced years ago when I had sent off the gauges to convert them to LED.
So now I'm stumped on what the problem might be. I can hand turn the worm gear on top of the small electric motor and see the odometer working. Anyone have ideas on what else's I can check while I have it apart? I suspect it could be the circuit board or the small electric motor but I don't know how to test or even what those parts are called. I have searched unsuccessfully for a diagram or listing for them.
Anyone any ideas on what to do next? Otherwise, I think I might have to ship off to a repair shop.
Thanks in advance for your help
Scott Rogers
scottr@wirestone.com
81 911sc Targa
99 BMW 328is Coupe
2007 BMW 328is Wagon
Last edited by scott_rogers; 02-22-2017 at 08:38 PM.. Reason: Didn't finish and accidentally submitted
Old 02-22-2017, 08:37 PM
Member 911 Anonymous
DRACO A5OG's Avatar
How is the solder joint on the green signal wire?
Then check the other suspects, ground connector, tunnel connection and the sensor itself.
'85 Carrera Targa
PCA/POC
Old 02-22-2017, 09:09 PM
Drisump's Avatar
If the speedo is working, the sensor is good and signal is getting to the instrument. Like you say, it is likely either the motor, the wiring to the motor or the board that controls the speed of the motor. Looks like it may be a job for North Hollywood. Cheers
Old 02-23-2017, 06:18 AM
Thanks for the replies, I ended up just doing a little cleaning on the gears and making sure everything seemed to be adjusted properly. I then tested the gauge back in the car. Amazingly it began to work again. I suspect if might have just gotten stuck or the problem is now going to be intermittent. If it happens again I'll just send it to North Hollywood, but for now all's good!
Scott Rogers
81 911sc Targa
99 BMW 328is Coupe
Old 02-24-2017, 07:09 AM
Cars and Cappuccino
tdw28210's Avatar
East Coast VDO repair shop.
Nichols Speedometer & Instruments - Speedometers, Tachographs, Service and Repair North Carolina
They did my gauges. Not a full blown custom shop a' la' N. Hollwood. More along of a repair shop, but fast and fair.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 02-24-2017, 07:31 AM
Thanks for the tip. Last time I used N. Hollywood it was really expensive so I was not looking forward to another bill. I will add this company to my notebook.
Scott Rogers
81 911sc Targa
99 BMW 328is Coupe
Old 02-24-2017, 08:11 AM
I have always felt that NHO is reasonable for the high quality repairs I have gotten. No way am I interested in experimenting with someone new......just my experience and opinion.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 02-24-2017, 01:38 PM
