Non-sliding left-right axle on one side causing damage? (911SC)
If an inwardly bent trailing arm is pushing inwardly on an axle such there is there is no lateral slide movement room on the axle that would normally be had toward and away from the wheel by grasping the axle with your hand when the car is on a lift, and the lack of movability left to right is not caused by lack of lube, then what would the effect be on the the transmission of the axle pressure against the transmission as the suspension flexes while driving in such a scenario?
Not certain what is causing your axle not to move, but I'm pretty certain that if your trailing arm was bent that far that you would have some serious alignment/drivability issues. I did a quick check on my car and I have ~3/4" inboard/outboard movement of the axle.
Have you pulled your axles and checked your CV joints? Could be that you have a SERIOUSLY dry joint, or a worn cage that is binding it up. Think it would be worth checking before you have an inconvenient, or worse yet catastrophic, failure. |
The question is not why. Rather the question is what damage can be caused to the transmission by having an axle that can't move in and out? |
At some point in the arc of suspension travel you should have mobility. If your suspension is so far out that you are either pulling on the joint or pushing it together, that would be a no drive situation. Is there any way you could have reversed the cages or other parts during assembly ? I did that on a Subaru once, and it bound up. Taking it apart and correcting the orientation solved the problem. It always helps if you have a good one to compare the problem unit to.
If I had to guess, I would assume that your problem lies somewhere along those lines. |
If someone in the past took the balls out of the CV joint, put them back together, easily, than the CV is a problem and reason the full unit doesn't move in and out.
Just a thought, Bruce |
http://forums.pelicanparts.com/porsche-911-technical-forum/936175-rear-wheel-position-mystery-911sc.html
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/946191-wtb-wanted-left-trailing-arm-911sc-immediate-need-please-pm-me.html http://forums.pelicanparts.com/porsche-911-technical-forum/946649-axle-slide-side-side-proper-one-side-but-other-side-tight-due-bent-trailing-arm.html http://forums.pelicanparts.com/porsche-911-technical-forum/946597-can-aluminum-trailing-arm-get-bent-yes-no.html http://forums.pelicanparts.com/porsche-911-technical-forum/947065-can-someone-take-exact-same-photo-undercarriage-911sc.html http://forums.pelicanparts.com/porsche-911-technical-forum/947088-aluminum-trailing-arm-casting-numbers-74-77-78-83-etc-cross-fit-911-331-513-a.html To summarize, you purchased this car recently, and the previous owner both knew about the problem, and tried to correct it. I presume you knew about it before purchasing. The car drives well, does not crab, and the primary evidence of the problem is the left wheel is inset much more thant the right side. The secondary evidence is that the left axle free play is absent. Other hints include the left lower shock mount, and the kink in the hard brake line. You also say that the left suspension droops more than the right when on a lift. http://forums.pelicanparts.com/uploa...1479576503.jpg http://forums.pelicanparts.com/uploa...1487800894.png Despite the left arm is cleaner than the right I do not believe that it has been replaced; the lack of axle free play, the shock bolt and the brake line suggest that the left arm is bent. The wheel bearing, the CV joints, the differential bearings and the pinion bearings are probably at risk of increased wear due to thrust forces that are not normal. |
If it was my car I would start removing parts and carefully measuring. Could be bushings, CV, bent arm, moved pick up points....
Hey, I got a novel idea:
Mark the axle shafts as "Left" and "Right" and the ends with "inner" and "outer" with a paint marker, piece of tape, whatever. Then remove both and swap sides. See if the limited movement in the axle goes with the axle assembly or stays with the chassis. If I remember correctly, on the SC at least and perhaps others, there is a foam sticky back gasket that gets applied to the CV joints (or the mating flanges....been a long time) where they mate up to the transmission flange and the wheel hub flange to help keep the grease from flying out. Can't be too much loss in motion due to one axle having them and the other not, but that's supposed to be there nonetheless. Disclaimer: I didn't sleep at a Holiday Inn Express last night. |
Others have given you tips on where to look for accident damage in the chassis. I know of one SC locally that was hit in the right rear corner to the point where the chassis under the oil filter area adjacent to the engine tin has a definite kink, the rear decklid fits poorly with regards to the gaps in the rear fenders and the rear overhang at the top corner of the fenders, the lower rear of the right hand door rattles against the rocker panel......yet the car is aligned perfectly and drives fine. Wheel offset differences: Somebody already mentioned the obvious of swapping the wheels/tires left and right to eliminate that. Plumb bobs and measuring from resulting marked reference points on a flat level surface would be reasonable. For that matter with the car on the ground and bounced a few times you could use a carpenters level and a few shims against the wheel/tire to roughly measure the camber of the rear suspension and compare side to side with the same air pressure in each tire..... |
The axle shaft itself effectively changes length as it travels upward and downward. The ball bearings ride along the race grooves to allow the axle to move in and out of each CV joint and thus changing its length.
With the trailing arm bent inward and the axle "frozen" in place, the axle has been pushed beyond its typical shortest length and probably wants to go even further beyond. Therefore the axle is pushed to its physical length limit and that means within the CV joint, parts are trying to go further than they allow themselves. Basically the inner part of the CV joints are trying to go beyond what the outer part of the joint will allow and something has to give and break. I also suspect the inner part of the CV joint could be contacting the cupped interior of the transmission output flange, which it's not supposed to do. As far as the influence on the transmission, it would seem the axle is pushing the transmission to the side and that is putting a load on the rubber mounts. Internally, it would seem the axle is putting excessive lateral force on the output flange, which is directly bolted to the differential. So the differential has lateral force placed on it, which is pushing one support bearing slightly out of its race and the other further into its race. One bearing is being slightly unloaded and the other excessively loaded. Plus, given that the problem axle is on the passenger side, the lateral force on the differential is trying to push the differential side cover away from the transmission. So the side cover is being flexed outward. When the side cover flexes outward, the differential ring gear would then be moving away from the pinion gear. None of this is good for the transmission. |
The drive shaft can be removed, but I suspect with a lot of difficulty. If it is bound up, or pinched in position, then there will be no free play to separate the CV from the flanges. I suspect that the whole arm assembly will need to be removed even to get the axle out of there. Once removed, the axle free play will be evident. However I think there will be damage done to the CV`s and the axle should be replaced. A replacement arm with sway bar connection should also be obtained.
It would be very useful to know what incident caused the damage; was a wheel replaced already? Normally the arm is designed to bend in an accident to prevent damage to the body whenever possible. Dave |
One of SCaddle's suggestions is not part of whatever is causing the issue here: the separate grease seal in the CVs. The presence or absence of this seal (I don't use them)has no effect on the overall length of the axle assembly. There is a machined cut-out recess for this seal in the output flange, but even with the seal in place there is metal to metal contact between the CV outer (the big part) and the rim of the flange. The seal itself is slightly compressed within this relief.
Some careful measurement and observation should show whether or not the torsion tube is bent or twisted. If it is, the relationship of the transmission mounts (which are welded to the torsion tube) would no longer be the same side to side or diagonal distances from other fixed measuring points on the chassis, or might be at different heights, or both. The centers of the two large transmission carrier bolts would be where you'd measure from. There are factory distance specs for measuring, but the key is variation from side to side. |
In my case the problem axle is on the driver's side. Does that make a difference to your explanation? |
KTL's explanation is a little off due to the wrong side analysis. However, as I said in a previous post, there likely are thrust forces acting on the differential bearings and the ring & pinion that are not normal. This could lead to accelerated wear on these components. If the inboard CV can be removed from the transaxle flange then you might have a good idea if the left suspension is pushed in towards the transmission; and if the free play in the drive shaft is restored.
I honestly have no clue as to how the left rear suspension could be shifted 5cm without making the car do odd things. I once hit a curb due to a large quantity of gravel across the asphalt on a ramp at an intersection; it was like driving on marbles. The left arm bent upon impact, but the car was still drivable even though it crabbed noticeably. The first thing I would do is to measure the distance between the lower shock bolts to the centerline of the transmission on both sides; they should be equal. The second thing I would do is to remove the CV from the transaxle flange, and check out the axle free play. Then redo the shock bolt distances again. If you can do these things and report the results, then perhaps we can do a bit more than speculate. |
I still contend that the axle would be a lot shorter when the suspension is fully loaded, simply because the angle of the driveshaft between the two points is greater when the suspension is at full droop. It just doesn't seem likely that the axle is fully compressed at both normal ride height and full droop unless the axle is pushing the swing arm in and out, and it is always under compression. That may be the case, but it takes a lot longer to try to theorize this problem than it would to take out the axle and examine it.
However, you could jack up the car and see if the length of each axle is the same at full droop, by measuring each axle from the same points. You wouldn't be looking for super accuracy as much as you would be looking for a major discrepancy. |
I had a bearing that was stuck in the cage on one of my CV's. but also, if you put the CV back together wrong it can bind up and not move. also as mentioned , if your trailing arm was bent that much you would have some real driving issues. bad toe on the rear can be way more exciting than bad toe on the front. |
a simple measurement of the outer flange to the inner flange on one side compared to the other would be the easiest test for alignment issue
Sorry for misinterpreting which side is the problem. My "summary" is the same except that instead of the ring gear pulling away from the pinion, it would be pushed harder against the pinion. That's still not good.
I agree with the other guys that an improperly assembled CV joint locks together and you can't make it move in/out and nor can you make it pivot. So it would seem to me that an improperly assembled CV couldn't be mounted because the the axle needs to pivot in order to allow the CV to bolt up with the trans output flange? The fact that one wheel is sticking out and the other is pushed very far in seems like the bent trailing arm is the issue here. The wheel pictured appears to be a 16x8 (because the lug nuts are not countersunk) and usually fills out the SC fender flare quite good. On the left side the wheel is sitting quite far into the wheel well. So I think the trailing arm is sitting too far inward on that side. http://forums.pelicanparts.com/porsche-911-technical-forum/936175-rear-wheel-position-mystery-911sc.html |
I agree that it is unlikely that a "backward" CV (locked) would get installed, though it would be possible to do it. Might line up well enough on the wheel side flange, which is attached first? If, in its locked state, you could not maneuver it over the transmission side flange, you could loosen the 8mm bolts on the transmission mount and shove the transmission over enough to get the clearance needed. I have done that on a SWB car adapted to LWB along with camber boxes. Rear tires align, but track (at the flanges) is just a hair narrow, and the end of the axle bumps into the tranny flange without this kind of fiddling.
Indeed, the first time a guy assembles a CV backward, after the panic of how to get it back apart subsides, all goes well enough - I can't imagine anyone so lacking in a feel for what should happen would just install it. You don't need to know just how a CV works (I continue to marvel at the human ingenuity which allowed Sr. Rezeppa to conceive this device)in order to realize things have to move, especially if you were the one who took the axle off in the first place, or pulled the old CV apart. Measurement would seem to be the key to pinpointing the culprit here. Is the transmission centered laterally on the chassis? Are the two chassis attachment points - the inner banana arm attachments on the torsion tube, and the outer where the torsion bars connect to the trailing arm, where they should be, or at least symmetrical. If so then it is hard not to conclude that there is a bent trailing arm. If, despite a bent trailing arm, the rear tires are both parallel(that is, have a slight toe in within the alignment specifications), then it should be possible to observe that the toe adjusters are set or clocked rather differently from one side to the other to compensate. |
I responded to one of your other posts that I had similar condition on my car. The driver rear quarter had been replaced, which I knew when I purchased the car. However, the tub was fine and I was unaware of any subsequent damage. I came to know I had issues because the driver side swing arm bushing kept compressing like it had been in the car 20 years, even though they had only been 20 days.
I started doing detective work. I pulled both rear torsion bars so I could look through the torsion tube. It was fine. There was also no visible damage to anything, including the rear banana and swing arm. I finally noticed that with the car level and all four corners in the air that the driver side wheel hung at an angle with several degrees more positive camber than the passenger side. Even though there was no visible damage, I concluded that the banana arm was bent - just by a few degree, but it was bent, so I replaced it. Grady Clay had once posted on this topic. There are factory jigs to show the arm is in spec, good luck finding one. It was his opinion that an arm could not be successfully straightened, even with a jig. No one wants to throw money and parts at their car, but you need to go beyond theory at this point. I would pull the rear suspension out. How do the t-bars look in the tube? Are they centered? Can you see through the tube - side to side with the t-bars out? Laser measurements are the most precise way, but you can see certain defects relating to the tube with the naked eye. If you suspect the banana arm, it's not that hard to replace. Find a good used one and replace it. You can accomplish all of that for less than $500 if you do the work. If the car still does not seem right, then you will need a high quality shop with laser measurement equipment to determine if there could be other body structure damage. Replacing the banana arm addressed the issues with my car. Good luck in your efforts to find a fix. |
| All times are GMT -8. The time now is 11:43 AM. |
