Ball Joint Socket???
I'm doing a full front suspension rebuild on my '84 Targa. New ball joints will require a special socket to properly install and I don't have one but would like to "rent" one if you have the tool. I'll pay postage both ways and some amount of rental, I just can't see buying this tool and never using it again!
I am located in the SW suburbs of Cleveland (Strongsville), Ohio Thanks in advance for your help.
Jay Traner 1984 911 targa 1923 STuTZ 690 Touring 2014 VW CC 2.0T 2021 Subaru Forester (Mrs) |
I think the sockets used for 4 wheel drive front hubs also fit the 911 ball joint. You may be able to check a local auto parts store to see. I have read this several places here over the years, but have yet to change out mine so cannot vouch.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
No. You need P-210 ball joint socket. I have one I will loan you. PM me.
I used a pipe wrench and treated the nuts as expendable. just a thought.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue Last edited by steely; 02-26-2017 at 06:35 PM.. Reason: correctd tool name |
I hear this works $20
https://www.amazon.com/OEMTOOLS-25965-Bearing-Locknut-Socket/dp/B004FDJDE2
1986 Bosch Icon Wipers coupe. |
I tried messing around with modifying a tool I had. Didn't work and eventually just bought the proper one. I'd lend you mine but from NW BC the freight won't be worth it.
84 911 Targa Carrera currently getting renewed |
Recreational User
Talking about the castle nut? A pipe wrench with a cheater works great!
+1 pipe wrench 5 ft pipe.
also, While C/A's are off, drop BJs off with mech and some cash, let him torque new hardware up to the 184 ft-lbs you need.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
I've got one. Let me know if still looking for one. I'm over here on the the east side (Kirtland).
- Steve '70 Tangerine 911T '86 Guards Red 911 '57 Black MGA |
Thanks for the replies, I have 2 offers including SteveDraz who is local (the Pelican community is a wonderful thing!). I'll have this all back together soon!
Ball Joint Socket Tool for Castle Nut (89 Carrera)
Hi Everyone:
Could I get on the list to borrow one of these as well? I will be happy to pay postage both ways. Eternally grateful.... Andy Smith |
Spiderman
Best people in the world on this forum, I got that correct tool nicely sent from someone and I paid all postage on the return trip.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Do NOT use the socket to remove the nut. It will booger it up and make it not usable. Like others said, pipe wrench and cheater to remove plus a little dremel cutting. The trick to putting on a new ball joint nut is to put a floor jack with a piece of wood under your socket/ratchet wrench. Put as much upward pressure as you can. Use a cheater pipe with your ratchet. You'll probably never over torque it.
Craig '69 911T |
I remember using a bit of heat, a large hammer and the multi purpose tool being part of a VW Super Beetle front strut to remove and install those nuts.
Spiderman
Mine weren't rusty so came right off using a little PB Blaster and the jack/wood/breaker bar method. If still on the car its easy. Wasn't re-using but simpler than grinding or hammering.
Summit Racing has the sockets for $10, no need to borrow.
Great! Does anyone know which of these sockets is the one to fit Porsche 911s pre-1990? I couldn't tell by the listing: https://www.summitracing.com/search/part-type/ball-joint-service-tools/section/hand-other-tools?N=4294950890%2B4294951499&SortBy=default&SortOrder=ascending&tw=ball%20joint%20&sw=ball%20joint%20service%20tools&cm_mmc=ppc-google-_-search-_-general-terms-_-k
Spiderman
For my 87, needed to look like the one our host sells. With the 4 small lugs. Not a socket with 6 faces. You can see if you look at the nut side of the ball joint.
