Senior Member
Superman's Avatar
Control Arm Orientation
Front control arms have cylinders at the end which hold bushings. I have installed the fancy poly bushings but I've lost track of which cylinders go on which side. The cylinders at the rear of the control arm attach to the cross member. Those cylinders have a guide welded to the side of them and it is through this guide that the long bolt goes, which holds everything together. The guide is slightly cone-shaped. It is wider at one end than the other. I need to know whether the wide end goes down, or up. It is fairly easy to see, so if someone does not already know, they can go peek for me. The part is cadmium coated, not black or aluminum like the others. It is clearly visible from the wheel. Like if you were a front brake caliper, you could see it easily.
Thanks, in advance.
Mocha 1978 911SC. "Coco"
Old 01-18-2003, 07:39 PM
Senior Member
Superman's Avatar
Anybody? I think the small end goes up, but not sure. Tell ya what. Whoever answers my question gets included in my prayers tonight and tomorrow.
Old 01-18-2003, 08:29 PM
chrisp's Avatar
Mine has the wider end on top.
Old 01-19-2003, 06:33 AM
Gasoline User
1974carrera's Avatar
Just checked mine and the wide side goes up. HTH.
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 01-19-2003, 07:25 AM
Senior Member
Superman's Avatar
Thanks. I had guessed wrong. I'll tell God you guys are really nice.
Old 01-19-2003, 08:54 AM
