Show me your brake cooler pics
I need some ideas for how to run my brake cooler hoses up to the front bumper. It seems like I may hit the hose with my wheel if I place it on top of the A arm. But it also seems that I may have clearance issues if I run the hoses under the A arm on my Euro height car.
Paul 1981 911SC/RS 2001 Audi A4 1.8T Quattro |
Administrator
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
The SR solution looks good. Autometrixhas this solution:
![]() I've also seen the hoses routed through the trunk, then holes get punched through the inner wheel well. If you just tie them to the control arms, plan on frequent replacements.
Chuck Moreland - elephantracing.com - vonnen.com |
Great post. I am looking at hooking up some hosing from my Rs bumper and want to figure out the best way.
C'mon guys help us out. More pics. I am not going spendy on this one. Zip ties and hose.
Brad Yantzer 81 SC 87 944s (dead, burnt it up) |
I have seen the expensive options out there, but I too want to do this without buying any more expensive parts. It also seems to me that the Smart Racing design is odd, in that the tire would come very close (if not hit) the front end of the tube. I can make my own fiberglass tube to mount in the exact same way, but it seems as though I could have clearance problems with the wheels. I do see from these examples that I need to run the hose on top of the A arm, and then maybe next to the tow hooks on the front of the A arm, then up to the bumper.
I am curious as to why using zip ties or a similar idea would cause me to need to replace hoses frequently. Is it because the ties break, or do they move around on the A arm too much?
That's why these type solutions exists, however expnesive. Routing through the trunk can be done inexpensively, but it is a commitment!
Thanks for the reply Chuck. If I understand this now, the "sleeves" that are attached to the A arms and carry the hose are to protect the hose from getting crushed by the suspension movement (i.e. pinched between suspension parts). I still don't understand where the hose is run after it exits the "sleeves" (Smart Racing), to prevent the tire from hitting it. I think I need to do a sleeve on the A arm area, then tie it as close as possible to the forward part of the A arm next to the tow hook.
I don't want to cut holes in the car to run a brake cooler, seems over ambitious to me. P.S. The race battery has been working great!
Stay away from my Member
Oooh, I thought those looked a little too cool...$600...ouch I am planning to use the Smart-Racing A-arm manifolds/brackets with AJ-USA diffusers, and run the hoses up to my front spoiler's inlets. That setup should be very effective and under $300.
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler |
Hi Chuck, I remember the ones you fabricated and soldered together.. They looked pretty cool.. now if you could make those in carbon fiber or even Fiber Glass that would be the *****!! JMHO
Jorge (Targa Dude) |
Pelican has a tech article on the installation of the A-Arm cooling unit
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
Irrationally exuberant
I've been running the Holbert Cool Brakes (tm) from OG Racing for years and they work great. I renew the zip ties about once a year. If something hits the (under A-arm) scoop it breaks the zip tie instead of the scoop.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
alum.
