-   -   Setting timing (http://forums.pelicanparts.com/porsche-911-technical-forum/94958-setting-timing.html)
htbetz 01-20-2003 01:00 PM
Setting timing
When setting timing on my bare bones 1974 2.7L do I dis-connect the vacuem line and plug the hose or leave it connected?
diy83sc 01-20-2003 02:12 PM
Try this ... I'm still considered rookie but found this that may be useful and specifc to you. You may have to paste the URL together...
http://forums.pelicanparts.com/showthread.php?s=&threadid=64728&highlight=timing+ hose+disconnect+74
Tony
Jim Sims 01-20-2003 02:54 PM
According to the spec book one leaves the vacuum line connected. For 1974 dwell is 38 plus or minus 3 degrees, and timing is 5 degrees ATDC at 900 plus or minus 50 rpm. Must be a lot of tuning up going on today!:D Jim
Early_S_Man 01-20-2003 03:28 PM
The following thread includes spec book procedure and timing data ... '74 USA data was the same as '72/'73 911T data.
http://forums.pelicanparts.com/porsche-911-technical-forum/5432-distributor-lube.html
