Setting timing
When setting timing on my bare bones 1974 2.7L do I dis-connect the vacuem line and plug the hose or leave it connected?
1974 911 2.7L coupe with sunroof
Old 01-20-2003, 02:00 PM
diy83sc's Avatar
Try this ... I'm still considered rookie but found this that may be useful and specifc to you. You may have to paste the URL together...
timing my engine...
Tony
Old 01-20-2003, 03:12 PM
According to the spec book one leaves the vacuum line connected. For 1974 dwell is 38 plus or minus 3 degrees, and timing is 5 degrees ATDC at 900 plus or minus 50 rpm. Must be a lot of tuning up going on today! Jim
Old 01-20-2003, 03:54 PM
Early_S_Man's Avatar
Porsche Crest
The following thread includes spec book procedure and timing data ... '74 USA data was the same as '72/'73 911T data.
distributor lube...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-20-2003, 04:28 PM
