nippy's Avatar
Any magic tricks to geting an old mirror puck off windshield w/out cracking the glass
We used a old school roof mounted rear view mirror in our new build and cannot get the old mounting puck thingy off the glass. We tried heat and chemicals and no go. Anybody have a good solution? Windshield is now back in car so I'm sure its not going to be easy. Thanks.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold)
Old 03-17-2017, 12:15 PM
Control Group
Tobra's Avatar
Protect the dash, take a needle with thread on it. Stick the needle between the puck and the windshield. Allow acetone to run down the thread and needle so it can get between the puck and the windshield, take your time. Probably glued on with cyanoacrylate(super glue)
Old 03-17-2017, 12:35 PM
And protect surfaces from drips!
Old 03-17-2017, 12:52 PM
nippy's Avatar
Thanks guys!
Old 03-17-2017, 01:06 PM
Send a message via Skype™ to Porboynz
A single smart smack with a hammer and a chisel = cracked windscreen. :-( I like the needle idea, just 10 years too late
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 03-17-2017, 10:21 PM
May the force be with you. I never had much luck unless it had been reglüed.
206 637 4071
Old 03-18-2017, 08:17 AM
a.k.a. G-man
Geronimo '74's Avatar
Dental floss?
Old 03-18-2017, 08:22 AM
cnielsen's Avatar
A small micro torch flame on the metal part will soften the glue while a pair of pliers rotates the clip as the glue softens.
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 03-18-2017, 08:38 AM
Sadly, I think this is the best response^^.
Don't know how Porsche attached the mirror base, but most manufacturers used a two part system that cured chemically. Those adhesives will not likely be released by solvents or heat. Some U.S. manufacturers used to use a vinyl based adhesive that could be softened by heat and carefully peeled off, but I don't believe Porsche used such a system. My only experience was with a '69 when the based simply fell off and I had to re-glue it. However, I don't know if the base or windshield was original to the car. It could have very well been a replacement windshield that a shop or PO glued the base onto.
Good luck.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-18-2017, 08:52 AM
Found this on Youtube, looks simple, but may be risky! Good luck!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 03-18-2017, 09:00 AM
Used a razor blade on mine. I was surprised how easily it came off.
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 03-18-2017, 09:11 AM
