I'm going to buy the FI book from Pelican. But before it gets here, I have a couple of questions to toss out.
I guess I figured that MFI was MFI until I began to read about slide valve vs. butterflys and different space cams for different size/cammed engines. So is an MFI setup off a say a 2.4 T not anywhere the performer of the MFI off an S? Can said T unit be made to run with something like a higher compression, bigger cam RS motor?
yes can rebuild your T MFI pump so that it will work well with a larger motor and different timing. But you will have to get it rebuild and have a new spacecam installed.
just my uninformed $0.02 others will know much more than I
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Warren Hall Student
As Tim pointed out a T injection pump can have the space cam swapped for an S type. Also, have you checked out all the info in the Pelican tech articles on MFI. The bible for MFI (Check Measure Adjust ) is there and you can download it.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
PRO Motorsports
Like others have said, you can swap the space-cam in the pump to an "S" space-cam.
But the expensive part is having the throttle bodies opened up to "S" spec. to match the pump. It's about $1000. Then you'll need "S" intake stacks. You can buy the "S" stacks, or find a set of early magnesium stacks and have them enlarged. And then there's the port size in the heads. You'll have to enlarge them to 35mm. About $300 for a macine shop to do that if you bring them the heads.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Slide Valves and "High Butterflys" are pretty much for pure race engines. Slide Valves are cool because at WOT they don't have a shaft running through intake like a butterfly system. Barrel throttles have the same benefit. I believe that the downside of both of these systems is that they can easily jam if dirt gets into the mechanism. Not a big deal on race engines which are kept clean and often rebuilt - but definitely a big deal on a street engine.
I'm not sure what the deal is with the high butterfly systems except that I suspect that it optimises the system around a certain harmonic or something esoteric like that. Unless you have an engine engineered to be optimised for the same set of parameters as the high butterfly system, I doubt that it will do anything noticable for you compared with a properly optomised stock style MFI system. In order to make things like high butterflys work better then a stock style system, you generally have to spend quite a bit of dyno time figuring out the correct recipe.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 01-21-2003 at 07:17 AM.. |
