TWJ TWJ is offline
TWJ's Avatar
3 prong vs 4 prong flasher / turn signal relay?
At the parts suppliers websites I see both a 3 prong and a 4 prong flasher/turn signal relay for my '72 911...what is the difference?
I also see different part numbers for the 4 prong... 90161830311 and 91461830311...again, what is the difference?
Old 03-20-2017, 05:05 PM
Administrator
Dmitry at Pelican Parts's Avatar
Give us a call at 888-280-7799 and one of our Porsche parts specialists will be happy to help answer your questions.
-Dmitry
Old 03-21-2017, 11:50 AM
gptom's Avatar
TWJ
Please post the answer as I am getting ready to investigate my flasher
Tom
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 03-22-2017, 10:07 AM
TWJ TWJ is offline
TWJ's Avatar
Tom, I believe the 4-prong with part # 91461830311 is correct for the '72. I have not spoken with anyone at Pelican about this, you may want to do that.
Are you having problems with your turn signals and/or flashers? If so what is the issue, maybe we can trade notes.
T.
Old 03-22-2017, 11:28 AM
gptom's Avatar
TWJ
I found my flasher behind the fuel gauge. It is 4 pin, with the same 914 number as you have listed.
The issue I am having is that at idle, both dash turn signal lights are flashing dimly. The turn signals themselves are working correctly.
I pulled the relay out & cleaned the contacts with deOXit & reflowed all of the solder joints. I have not put it back in to test if that has helped
I replaced the original voltage regulator, thinking that the contact type was not charging at idle. I have also cleaned all of the ground connections. I do NOT have LED bulbs
Tom
Old 03-23-2017, 10:43 AM
TWJ TWJ is offline
TWJ's Avatar
Thanks for posting this information Tom. Unfortunately I haven't seen the problem you've outlined so I can't add anything. Maybe someone else has?
My turn signals and flashers aren't working at all and the new relay I purchased (91461830311) now blows the fuse when I turn the blinker on. ???
Old 03-23-2017, 11:21 AM
