Please help me figure out the climate ventilation system
so ive tried every combination of the levers and i cant seem to find the right position for what i want.....if it exist
all i want is to get outside air in thru the dash vents facing me to provide some cool air while driving....without running the AC
in my old mercedes we have the Economy button which provides that...
is this possible in the porsche or do i have to turn the AC knobs on to get such effect
also, whats with the defrost, i have two levers on the ground and one on dash...i dont get how im supposed to use them
thanks
1989 Porsche 911 Silver Anniversary Edition
1985 Mercedes Benz 500sel Nautical Blue
2012 Mercedes Benz E63 AMG Iridium Silver
Old 03-21-2017, 08:49 AM
No fresh air will come out of the dash vents. Take a look at this photo in post 11:
Mysterious climate controls....
also, there is a ton of information on this website...consider using the search function as it works pretty good.
Old 03-21-2017, 09:10 AM
Yes, I was about to post the same link.
Study the picture of the dash controls at the bottom left of the photo. Those levers will control the outside air volume, distribution, and fan speed of the fresh air blower with no connection to the AC.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-21-2017, 09:16 AM
great minds think alike?
Old 03-21-2017, 09:33 AM
You could try turning on the AC fan, and turning the AC temp to the highest temp, or disconnect the AC compressor.
1986 3.2 to 3.4 conversion
Old 03-21-2017, 09:46 AM
I believe the only way to get fresh air out of the dash vents is to have a car that was built with a non-AC ventilation system (one slider on the upper row instead of two)
'80 SC Targa
Avondale, Chicago, IL
Old 03-21-2017, 01:13 PM
Fleabit peanut monkey
Bob Kontak's Avatar
If you (vdub) use search, use the PP advanced search function.
Alternatively use google advanced.............
Here's a search in the 911 tech forum domain on "Fresh air vents" using google advanced. Also use Google Advanced any time you are searching on numbers. PP's search engine does not handle numbers.
https://www.google.ca/search?as_q=fresh+air+vents&as_epq=&as_oq=&as_eq=&as_nlo=&as_nhi=&lr=&cr=&as_qdr=all&as_sitesearch=http%3A%2F%2Fforums.pelicanparts.com %2Fporsche-911-technical-forum%2F&as_occt=any&safe=images&as_filetype=&as_rights=
1981 911SC Targa
Old 03-21-2017, 01:31 PM
Bob Kontak's Avatar
Thanks for that link. It does show you can get fresh air thru the defrost vents.
1981 911SC Targa
Old 03-21-2017, 01:34 PM
Member 911 Anonymous
DRACO A5OG's Avatar
'85 Carrera Targa
PCA/POC
Old 03-21-2017, 02:37 PM
Cars and Cappuccino
tdw28210's Avatar
Originally Posted by DRACO A5OG View Post
sarc/on....Easy peasy....sarc/off
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 03-21-2017, 02:43 PM
thats guys ill do some reading
Old 03-21-2017, 03:28 PM
Where is the non-A/C image for those of us less fortunate (or more weight conscious)?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-21-2017, 04:30 PM
Bob Kontak's Avatar
Believe image is from a later 911, 3.2, slightly more fisticated than older 911's.
Fresh air is up or down. Defrost or foot. Mix it with heated air.
Three systems. Fresh air/AC/Heat.
1981 911SC Targa
Old 03-21-2017, 05:10 PM
Cairo94507's Avatar
That diagram made my brain hurt......
'71 914-6 #0372
'17 Macan GTS
Old 03-22-2017, 06:01 AM
If you accidentally leave your front trunk open (caught on the safety latch) you will find that tons of fresh air makes it by the vents and every other opening in the dash.
On a serious note I have separated my blower motor and A/C compressor switches so I can run the blower without A/C although I will say I rarely do this.
Chuck.H
'89 TurboLookTarga, 429k miles
Old 03-22-2017, 11:48 AM
SweetWaterSurprise's Avatar
That pic is great.
Old 03-22-2017, 12:57 PM
Always learning something
Oyagi's Avatar
I swear the climate control system in my 930 is pure German engineered garbage. Just brutal. All my Japanese cars of the same vintage were so nice and logical.
1987 930 Guards Red
2004 Acura NSX Supercharged
2020 Macan S
Old 03-22-2017, 01:21 PM
To get any air out of the center vents, the AC system has to run. You can unplug the clutch if your don't want the compressor to run, like on a track day or autocross. The air blowing out will not be "fresh" air. The AC system on a 911 is 100% recirculated air. The air is drawn from the passenger side foot-board area. If you want some fresh air at all, turn the fresh air blower on, and have it blow out the heater vents. That will put some fresh air in the foot-well area and get sucked into the AC system.
I am one of the people that just never run with the windows down. Either the AC is on, or the heater is on. I use the fresh air system only on the track. And I do roll the windows down then since that is part of the rules.
Old 03-22-2017, 01:30 PM
Tori's Avatar
Looks like i need to make the labeled pictures i was planning on doing last year..... as i had the same questions. Now it's been so long since i've driven my car, i'm afraid i'll have forgotten how to operate the dang system. LOL
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 03-22-2017, 04:34 PM
Tori's Avatar
For instance: IF YOU HAVE YOUR CONTROLS SET THIS WAY,........ THIS IS WHAT YOU GET.
( and hopefully i have this correct.... please correct me if i'm wrong )
Old 03-22-2017, 05:01 PM
