JamesUK
Anyone use a diffrent design Window switch?
I have OEM. To me it seems the design is not robust. By that I mean the toggle switch itself, the movement that is there other than up and down. I noticed that 924/44/68 cars use a simple rocker switch. Seems to me that would not have the same issues as our 911 switch. Has anyone replaced the 911 switch with a different unit completely?
I know I started an earlier thread but I could not work out how to change the name to better describe the information I was really looking for.
Old 03-24-2017, 10:22 AM
The 924 et. al. use VW/Audi switches... they are Audis.
See your other post on the same exact topic.
Old 03-24-2017, 10:50 AM
Been here a while
there were some old threads about 80's BMW switches, nice design, push-button for up/down, used similar spade connectors, and almost the same size, slightly larger, so some minor modification to the door panels required.
looking for 1972 911t motor XR584, S/N 6121622
Old 03-24-2017, 11:22 AM
Administrator
Dmitry at Pelican Parts's Avatar
Check out your other thread, we posted some suggestions there.
-Dmitry
Old 03-24-2017, 12:32 PM
FrenchToast's Avatar
Actually, the 924/44/68 use Porsche-designed switches. The internals may be VW parts, but the cosmetic switch is not a VW/Audi piece.
The switches from the revised interior are also used in the 928, 964 and 993. (However the window switches are not shared - with the exception of one rare 993/996 model).
As for if the window switches are better or stronger, I can't say. However they are not plug and play.
Most modern window switches seem to be fairly robust, however are usually meant for mounting on a horizontal plane (armrest) and would be awkward on a vertical panel.
Old 03-25-2017, 05:36 PM
