Hodgey's Avatar
Porsche Crest Restart is Imminent!!!
Hello All....
Ready to get the girl off the jackstands and on the road...thinking about turning the engine over to lubricate it/build oil pressure without starting.....
Is the easiest solution to pull the fuel pump fuse? I'll be in the compartment taking the battery tender off....
TIA
Neil
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 04-02-2017, 05:30 AM
RETIRED
Joe Bob's Avatar
Disconnect the ignition. Or pull the plugs.
2012 ML350 3.0 Turbo Diesel
Old 04-02-2017, 09:21 AM
Rescuer of old cars
Arne2's Avatar
I like to pull power from the fuel pump (to keep unburnt fuel from washing oil from the cylinders), and cranking it with the plugs removed to build oil pressure with as close to zero load as possible.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 04-02-2017, 10:18 AM
Diss Member
Quicksilver's Avatar
On a Motronic car you just disconnect the reference sensor and as far as the whole system is concerned the engine isn't spinning.
Once you have oil pressure you can reconnect it and you are off and running.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 04-02-2017, 11:01 AM
Hendog's Avatar
Dme relay?
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 04-02-2017, 08:20 PM
