oil S hose
Looking at this hose, it looks like it is delaminating. I'm guessing if this fails it's a good way to dump all the oil in a hurry.
Is this line between the oil tank and the cooler what is referred to as the 'S' hose? and I assume 911-107-233-00 (with new clamps) is the replacement. Any 'gotchas' when replacing? How tight do the clamps need to be done up?
1983 911SC
2005 911S
Old 04-07-2017, 05:24 PM
Is that delaminating? Or is it the remnants of a part # sticker? Clean it and see. Replace it while changing your oil and keep the pan under it , re use your clamps. One of the easiest oil hose to replace.
Old 04-07-2017, 06:10 PM
As easy as brushing your teeth.
Old 04-07-2017, 06:16 PM
Old sticker remnants......
Nikos,
Spend some time cleaning and removing the old paper sticker on the S-hose. I don't think it is delaminating because the rubber hose is not laminated but rather extruded or molded rubber. It would dry rot and crack but not delaminate as you stated. Keep us posted.
Tony
Old 04-07-2017, 06:20 PM
proporsche's Avatar
Hi Niko..as the boys mentioned above ..there is nothing wrong with you oil S hose(at least no on this picture to be seen).Unless you see a crack on one of each ends there is no worries.To make it tight..use only hand no power tools.
Ivan
Old 04-08-2017, 12:00 AM
But, if it is 20 years old, it is probably hard as a rock. So, next oil change, add that hose to the work. It is actually one of the cheaper Porsche hoses to buy.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-08-2017, 08:36 AM
proporsche's Avatar
His does not look 20 or even 10 year old.It still had a sticker on it...plus someone just did a service they would see if it is bad...
ivan
Old 04-08-2017, 08:57 AM
If you ever replace it, I got a hint of someone overhere: make sure that the seam is at top of the hose.
For the best wipersblades in The Netherlands and Belgium: www.nieuweruitenwissers.nl
Old 04-09-2017, 12:50 PM
88 Carrera, Guards Red
azhodge's Avatar
You are kidding me friends, right??? If you have to ask, change the damn hose. Not even worth analyzing. Next oil change, replace it. Its what you don't know that is going to kick your ass. This is an easy pain preventing decision...
Old 04-09-2017, 06:01 PM
RETIRED
Joe Bob's Avatar
ALMOST blew my engine.....
My experience....
2012 ML350 3.0 Turbo Diesel
Old 04-09-2017, 06:10 PM
83 911 Production Cab #10
JJ 911SC's Avatar
+1, less then $25. Replace and keep the old one in the frunk as emergency spare.
Who Will Live... Will See
Old 04-09-2017, 06:33 PM
KNS KNS is online now
I just replaced mine with a genuine Porsche hose a couple of months ago. I replaced it several years before with an OEM hose and that one was hard as a rock. Neither one of them had a seam.
Kurt
Old 04-09-2017, 06:58 PM
RETIRED
Joe Bob's Avatar
Look inside....
Old 04-09-2017, 07:19 PM
John W
What's the typical life time on this hose? Thanks.
John
89 3.2 Targa 123k miles
Old 04-09-2017, 07:43 PM
While you guys are right that it was notdelaminating, it's as hard as a rock - so I'll swap it out before refilling with oil.
1983 911SC
2005 911S
Old 04-10-2017, 06:21 AM
proporsche's Avatar
Hi Niko..you will be surprised how hard is to squeeze the new one too..I have mine on my 911 since 2008 and it is still ok...no problems...
Ivan
Old 04-10-2017, 06:35 AM
