Passenger Window Control
Hi All
I can lower my passenger window with the driver's side switch but must use the passenger to raise it. Any ideas?
Thx
Old 04-20-2017, 04:17 PM
Alex599's Avatar
I would say that it's most likely the switch. Have you checked if all the wires are well connected?
1984 Carrera 3.2 Cabriolet
Old 04-20-2017, 04:28 PM
Spiderman
Jesse16's Avatar
If the switches are old, I would get a set of 3 (the OEM ones) on order anyway as you will at some point need them. If you are sure they are hooked up same as when they did work, then almost surely is a bad switch. In ten years and 100k of driving I've replaced mine at least once. They are only mildly robust in design.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 04-21-2017, 05:17 AM
Administrator
Dmitry at Pelican Parts's Avatar
Take a look at the link below from our site, it'll help you address the issue.
Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
-Dmitry
Old 04-21-2017, 08:40 AM
