Looking to do this job soon.. but when searching for tools, Pelican Parts lists this as for "installation only"... why?
And if it's for install only, then what do you use to remove? ![]() |
My guess is you potentially have to use a bunch more torque and shock to get a frozen ball joint off then the amount to install it. Perhaps this tool can't take that kind of abuse.
If you are replacing everything cut it off. Anything short of that will likely end in frustration and you cutting it off any way.
1982 911 Targa, 3.0L ROW with Webers |
cut what off?
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold ![]() |
Targa_PB_78_SC
I don’t know about this tool, but the one I bought in ‘97 worked fine on removal of my ball joints. I layed on my back and used an air wrench to get the nuts off,
The ball joints are secured by a ring nut that's nearly impossible to get loose. I ended up cutting a slit in mine with the angle grinder.
![]() you can follow my progress here: DIY Front & Rear Suspension Overhaul - Youtube video series
youtube.com/bennyobscene |
Chisel and BFH or a big pipe wrench.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
ahh cut off the old ring nut. DUH. already got them off without much problem.
new ones installed from ER.
