DIY upholstery is something I have wanted to attempt. Thanks for the encouragement and look forward to your video. Not feeling confident I can master a sewing machine.
Old 04-13-2017, 08:45 AM
Jacksonville, Fl
Hats off to you, sir. My square weave install has been daunting, and I cheated and got the carpet kit. You seem to have a nack for it though!!! Kudos!
Alex
Jacksonville, Fl
'88 Carrera, Guards Red
Old 04-13-2017, 08:55 AM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Thanks all. Why daunting? Have you tried a steamer?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 04-13-2017, 09:44 AM
Jacksonville, Fl
Had some issues getting it to lay flat and smooth, haven't tried the steamer though. That might be the ticket for some of those humps and concave curves in the rear seat area.
Alex
Jacksonville, Fl
Old 04-13-2017, 10:41 AM
Rennch on YouTube
rennch's Avatar
That is what I've heard is the hit way to make it happen. I'm ordering mine from Amazon.
Michael O'Neal -
Old 04-13-2017, 02:59 PM
Rennch on YouTube
rennch's Avatar
Test fit in the car looks really good.
Michael O'Neal -
Old 04-13-2017, 03:00 PM
@ emptyo --- have you looked into a "binder" adapter for Singer?
https://www.youtube.com/watch?v=Y8GFjQfc-n0
Doesn't seem cost prohibitive, less than $15 @ Walmart. But not sure if it would accommodate thick carpeting and vinyl binding material
https://www.walmart.com/ip/Distinctive-Binder-Sewing-Machine-Presser-Foot-Fits-All-Low-Shank-Snap-On-Machines/40649395?wmlspartner=wlpa&selectedSellerId=1278&adid=22222222227028393384&wl0=&wl1=g&wl2=c&wl3=61181426049&wl4=pla-96571880169&wl5=9031969&wl6=&wl7=&wl8=&wl9=pla&wl10=112561844&wl11=online&wl12=40649395&wl13=&veh=sem
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 04-13-2017, 05:12 PM
Rennch on YouTube
rennch's Avatar
Originally Posted by 83_Silberpfeil View Post
I have. The issue I have with that is you'd see the thread exposed, which isn't a look I'd like for this kit. It certainly would make my life easier...but sometimes it's more work to look the part.
Michael O'Neal -
Old 04-13-2017, 06:24 PM
Rennch on YouTube
rennch's Avatar
Plus, then I'd have to be good at stiching / sewing...which I'm not.
Michael O'Neal -
Old 04-13-2017, 06:28 PM
@emptyo --- wow, the details and subtleties that goes into it. Thanks for pointing those out. Indeed, getting it right --- or at least the exact way you want it --- does always require more work. But at end of day, totally worth it. Good luck w rest, look forward to seeing more.
Old 04-13-2017, 07:41 PM
Rennch on YouTube
rennch's Avatar
Steamer ordered!
Michael O'Neal -
Old 04-13-2017, 07:43 PM
somoney311's Avatar
What kind of steamer did you order? Looks like a project I would like to try since I need new carpet anyways.
James
1989 Slate Grey 930...sold
Looking for the next one!
Old 04-14-2017, 11:31 AM
Looks really great!!
I have a strut brace going into my frunk, which requires a hole to be cut into the carpet there to accommodate the camber plate attachment (pic below - credit to Elephant Racing - only shows a "floor carpet" but mine goes up the sides). I'd like to get a grommet to install in the carpet to protect that area - any ideas?
Old 04-14-2017, 11:51 AM
Administrator
Dmitry at Pelican Parts's Avatar
Looks great Michael - try to make it to our Coffee & Cars on May 20th so we can see it in person!
https://www.facebook.com/events/1268272376627285/
-Dmitry
Old 04-14-2017, 12:06 PM
dlagerstrom's Avatar
I love this. Looks great, congrats.
Couple of questions:
- Are you using a walking foot?
- Is the binding the 4-way stretch:
- How does it go around the curves?
Looks like my next DIY learning challenge!
Thanks.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 04-14-2017, 12:53 PM
Rennch on YouTube
rennch's Avatar
-Dmitry
I'm getting it ready for luftgekuhlt, so it will be there. And I will definitely try to make your event!
Michael O'Neal -
Old 04-14-2017, 05:52 PM
Rennch on YouTube
rennch's Avatar
Thanks.
Number one: yes to the walking foot. Number two: I'm not sure if it's a four way stretch binding. Might just be vinyl. Number three: pretty well. So far it is handled a 90° curve with no problem.
Michael O'Neal -
Old 04-14-2017, 05:53 PM
Rennch on YouTube
rennch's Avatar
I ordered it last night from Amazon, and it came in today. It was rated well.
Michael O'Neal -
Old 04-14-2017, 08:45 PM
Rennch on YouTube
rennch's Avatar
DIY Carpet Cutting, Binding, and Install
Well, this one really kicked my butt tonight. I thought I would pick a pair of big, easy ones, but this one was quite complicated.
First things first, to maximize your carpeting, you definitely want to lay out all of your pieces before you start cutting. You also want to use as many common edges as you can.
I decided on this one, which is the drivers side floor mat, to extract the piece of reinforced vinyl that wraps around the Accelerator pedal.
It was a fairly tedious process, but I finally removed it, scrubbed it with some hot water and soap in the sink, then pressed it flat with an iron and a paper towel between.
This piece was pretty beat up, and the default installation is glued and then sewn.
On my original Matt, the edges were raw. I wanted to have a finished edge, so I thought I would fold over the parts that were exposed.
Once I cleaned it and scrubbed it and ironed it, it looked pretty decent on the mat.
I then went around the perimeter of the vinyl with a stitch.
I thought I was home free, but boy was I wrong. The area that wraps around the accelerator pedal was my most challenging binding to date. This particular mat took me over three hours to finish. It was a real bear.
One of the main issues is, I'm struggling with how thin my binding is. I bought the 1 inch finding from global upholstery. I think it would be a much easier project with 2 inch binding, but that was not available. It means that, on the underside of the mat, I don't have a lot to work with. I Think once I finish the passenger side, I'm either going to make my own binding out of black vinyl, or find some 2 inch binding to purchase.
Either way, it came out really great, and I am one more step in the right direction.
My goal is to have the entire carpet kit finished this weekend, so it's ready to be installed next week when my car comes back!
Michael O'Neal -
Old 04-15-2017, 02:16 AM
somoney311's Avatar
Wow, that looks awesome!
James
Old 04-16-2017, 11:59 AM
