Shift Coupler Bushing - Removal & Replacement
So, had success in removing the shift coupler this evening. However, when it comes to removing the pin from the coupler to free the old bushings --- no cigar.
Does the lubricant sprays help?
As you can see the bushings are crumbling!
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 04-14-2017, 11:48 PM
emac's Avatar
The pin has to be pressed out. I used a larger diameter socket that fit on the metal part of the coupler- then a smaller on the other side. The challenge was keeping it straight in the vice
Old 04-15-2017, 12:07 AM
wayne robson's Avatar
pin remaval
Hi -Will try and help you with a few tips on removing the pin.
Sorry i can not send photos as i dont have a spare coupler,but will try explain.
First you can not always rely on using your vice,because it has to be a solid base
or of strong steel or similar to stop any bounce when hitting pin.
Another good base to use is a solid wood table with solid vertical legs,you place
the coupler on a end table directly above one table leg ,drill a haif inch hole in center
of leg,place coupler right above it ready for hitting.Last one i did , did not have to
place socket under it, but we have really hard wood here in Australia.
The first thing to do is make two small hard wood wedges about 1inch by half inch,
tapered from about 1/16 to 1/4, tap into the shoulder of coupler, you can see in your 4th from
top photo.This helps to stop breaking or cracking the coupler when you hit the pin.
Then you need a solid round steel bar about 6 inches long comfortable to hold,
slightly less diameter than the axle pin.Then you are ready to belt the pin out
with a good hammer. Solid base is the trick.
Old 04-15-2017, 03:40 AM
Brew Master
cabmandone's Avatar
I had a piece of thick flat stock steel with a hole drilled in it that I used to remove my pin.
Old 04-15-2017, 03:50 AM
I used something like a Black & Decker Workmate - I think I pushed the pin out through a gap in it or something. Regardless, it does need to be clamped well and the pin pressed out.
'80 SC Targa
Avondale, Chicago, IL
Old 04-15-2017, 05:22 AM
Thanks everyone for chiming in with your tips and tricks! Great way to start a Saturday morning --- seeing a bunch of replies --- awesome bunch here.
I used a 1/2 PCV irrigation pipe. Cut about 1.5" long and placed under the coupler (sitting on the side). This way, the pipe wall sits on the bushings, and allows the pin to be punched thru.
On the direct opposite side, I used a 11 or 13 mm socket directly on top of the pin and whacked it w hammer. Gave it a dozen whacks or so, but would not budge.
Will try the combination of your suggestions next.
Thanks again!
Old 04-15-2017, 08:41 AM
Check out this video
https://www.youtube.com/watch?v=LAD0PoC8mzo
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 04-15-2017, 09:33 AM
Great video JSV!
Thanks for sharing
Old 04-15-2017, 09:45 AM
Ed's video is great! Just don't have the tools needed --- don't even have a workbench, and vice LOL. That drift he uses will cost me $40 @ Harbor Freight. May be a new $85 coupler from our host is way to go? Figure I can sel my old one for ~ $40???
Would a local auto repair shop have a press to do this for me for say $20 or so?
Old 04-15-2017, 09:50 AM
Perseverance, some creativity, and a little help from Harbor Freight ($7.50 punch set w coupon LOL).
Got the pint out w/o damaging the pin (too much LOL). Next, install the bushing purch'd from our host, and then re-insert the pin... stay tuned!
Old 04-15-2017, 11:59 AM
I am going to look for that $40.00 HFT drift today at my local store.
OH GEE here is a set of 8 for $8.99??
8 Piece Pin Punch Set
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 04-15-2017, 12:13 PM
That's the one I bought, the $8.99 set --- $7 and change after coupon/taxes. The laeger diameter punch was enought for the coupler pin.
Old 04-15-2017, 01:31 PM
Got the pin back in.
Problem: does not swing freela as shown in Ed's vedeo belo @ 6:50 mark
What to do?
https://youtu.be/LAD0PoC8mzo
Old 04-15-2017, 04:00 PM
Tried it again --- removed the pin, and re-installed.
My observation:
The pin rotates freely inside the bushings --- not exactly "freely" as in Ed's video, but when I give it some force and move the coupler shaft, I can see that the pint moves inside the bushings.
Cannot see it but seems like the pin is fixed inside the coupler shaft.
Should the pin move freely inside the bushings? Should the pin move freely inside th coupler shaft??
Getting frustrated here, but not giving up!
Old 04-15-2017, 06:34 PM
emac's Avatar
You got it right the first time. Reinstall and enjoy the fruits of your labor.
Ernie
Old 04-15-2017, 06:59 PM
Thank goodness! Appreciate you taking a look Ernie. The shifter ball bushing and the rod bushing are next, then put everything back together.
Old 04-15-2017, 11:29 PM
