Tony
Good way to keep steel lug nuts from rusting?
See below, think paint would come off, any idea?
Tony 22 GT4 04 E46 M3 87 Carrera (sold - craving aircooled again) 12 991 Carrera (sold) |
Severe Automotive Issues
Anti-seize grease will keep them from rusting at the tread. It's also a good idea to place some at the seat of the wheel with the center. It keeps you from having to kick the tires to get them off. Maybe give the nuts a dip in phosphoric acid, it gives steel a protective coat. If that is not easy to find (as in you are not near a coast), the makers of pblaster make a product called corrosion stop, that works wonders.
Formerly known as Syzygy
Phosphoric acid is available from lots of places as it's a great converter of rust and is often used to prep metal for paint or other coatings. You can probably find some at Lowes or Home Depot or a cleaning supply house or naval jelly or Ospho or cola or...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 04-15-2017 at 10:55 PM.. |
Try powdercoating them? Or soak them in Gibbs and just let them air dry.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
Uncertifiable!!!
Yes, a constant problem. Zinc coating is expensive and mars easily. I have given up and now just periodically wire wheel the nuts and ends of the studs followed clear coat and some heat to cure/harden. A soft socket form our host helps. As "scary" said, anti-seize on the threads helps.
![]() Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
There is probably some fancy coating one could use. I wouldn't try powder coating...
Blacksmiths used to (and probably still does) treat stuff with linseed oil, heated the steel and dipped in the oil. It created a black finish that had a protective effect. The bluing on guns gives a rust protection to, doesn't it?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
best options are Cerakote and black zinc chromate
There are also some rattle can paints that harden when baked. That would be your cheapest solution and would probably be ok with some twill pants fabric over the nuts when tightening/loosening.
Tru6 Restoration & Design |
