IS300's Avatar
can changing motor mounts mess up alignment???
changed my motor mounts and tranny mounts... put the car back together, set her back on the ground and noticed my gt3 exhaust doesn't line up below the license plate, and the rear wheels don't have the same fender clearance .... does anyone know what has happened??? thanks Anthony
Old 04-15-2017, 03:51 PM
How was it raised? Jack points? Or torsion bar. Any rust? Have you driven it to settle suspension?
Old 04-15-2017, 04:37 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Why have you not stated that you have an 82 SC in this thread? Fix this, point forward. Reading your post, you have a GT3. How could we know otherwise unless we dig into your old threads? 300 plus posts. It's time. Be kind. I will cut you.
Drive the car. Settle suspension. Take a look. I suspect the wheel well stuff will clear as 911obgyn states.
Bruce Anderson noted to loosen trans and engine mounts at the same time, to loosen up the lump. Then re-tighten. Engine assy can get wonked when you tweak with a jack not raising engine symetrically.
The thing I never understood about his thoughts were what happens. Maybe just some binding shakes free?
1981 911SC Targa
Old 04-15-2017, 05:04 PM
IS300's Avatar
I'm sorry boss..... freaked out... I am still newbie .. please forgive ...
yes 1982 Sc I have a m&k gt3 exhaust.. I replace all four mounts this winter... no rust, have not driven it, had it up on jack stands (on the torsion bar ends) jacked up one side then the other, same when taking off the stands...
was thinking to loosen all four mounts .....at the same time and??? help
Old 04-15-2017, 05:47 PM
Formerly known as Syzygy
Canada Kev's Avatar
As Bob says, 'tis good to put your ride info in your signature so we know what the hell your talking about to offer appropriate advice.
But I have no advice except for your ride height. It'll likely settle after you drive the car a little.
Kevin
Old 04-15-2017, 06:07 PM
911SC Tinkerer
merlinfe's Avatar
Is this the single in M&K? It's easy to have it get a little misaligned. Brian even says that it takes some finesse to get it lined up right. Maybe it just got bumped?
If it's dual in, then I'd worry a bit.
-Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 04-15-2017, 06:48 PM
IS300's Avatar
its 2 in 2out
Old 04-15-2017, 07:26 PM
Bob Kontak's Avatar
SAY MY NAME! LOL.
Settle it with a drive first.
Don't disregard the loosening all four mounts then re-tighten. I gotta think you can balance the eng/trans assy with a floor jack with the car elevated at all four corners. I can't vouch for this but if The Bruce says it, there is something to it. Let me see if I can find his passage and post it. (Lemmie get this to you first) He did not state this to rectify physical alignment issues, I think it had to do with shifting issues. Binding and such.
Can the exhaust be adjusted at the lower engine harness? Does it have the strap thingies? Has to have some tweakage there but then if you get into it deeply you will be taking gaskets off the mating points. Not at the heads, at the muffler join with the headers.
1981 911SC Targa
Old 04-16-2017, 02:27 PM
T77911S's Avatar
tranny mounts have NO effect on wheels or suspension alignment.
as far as exhaust, are you talking left to right or front to back as in it does not stick out as much.
I don't remember on the 911 but my 930 has 2 sets of holes for the tranny bolts.
how was it bolting everything back up. the engine mount bar line up ok and the tranny bolts line up ok.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-17-2017, 05:59 AM
Administrator
Dmitry at Pelican Parts's Avatar
If you're still having issues with the alignement, take a look at the link below to our site's DIY tech article on aligning your P-car. Hope this helps you troubleshoot.
Porsche 911 Alignment Overview | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
-Dmitry
Old 04-17-2017, 10:28 AM
