beancounter
jwasbury's Avatar
Thumbs down greasing poly bronze bushings
Is it just me?
Every time I do this job, the grease goes everywhere but into the bushing. I have the grease gun nozzle engaged on the nipple, but the damn grease just goos all over the nipple and nothing seems to go in. I've tried two different grease guns...same thing happens.
Is there some special nozzle I need to make this work?
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 04-20-2012, 04:16 PM
KNS KNS is offline
I've had this problem, it's frustrating. You have to really push the tip on to the grease fitting. Sometimes the tip of the grease gun will interfere with the spring plate cover or something else and not be fully seated, you just can't see it.
What I did is grind down the tip of my grease hose/nozzle to a rounded or conical shape. This really helped a great deal. Of course you have to clean the tip thoroughly and run some grease through it to flush out any particles.
Kurt
Old 04-20-2012, 04:36 PM
ROW '78 911 Targa
timmy2's Avatar
Have you tried swapping out the grease nipple yet? They do seize up, especially if they see a lot of water and dirt.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-20-2012, 04:44 PM
Recently Disbanded
juanbenae's Avatar
i have found that even when you get it seated & get the grease through the zirk it all seems to squeeze out right within an 1" so of the fitting. spoke with chuck on this and he pointed out the amount of grease to fill the inner races is so minimal that by the time it daylights outside the joint they are full. id still like to see some grease push out the far side... still very happy with them & as with most of his parts they are the last thing to be concerned about when im tinkering with suspension set up. with friends of course,,, cause mine set up a car better than anyone i would ever pay could...,
Old 04-20-2012, 05:08 PM
:d
Old 04-20-2012, 09:19 PM
j911brick's Avatar
Could be the grease gun. Most of them are crap these days. I found the John Deere brand to be about the best.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 04-20-2012, 10:15 PM
303462's Avatar
grease
+1 on grinding the nozzle a little for a better angle. I use the rubber flexhose and the small one hand pistol grip gun. With this gun the other hand is free to hold the nozzle tightly on the zerk. Works very well.
Old 04-20-2012, 10:33 PM
Max Sluiter
Flieger's Avatar
Someone should make bushings that do not need grease...
Old 04-20-2012, 10:40 PM
I don't miss the maintenance of the the polybronze I had on my SC.
I like the ER rubber on my 86. Trouble free and most of all dirt free.
2007 Cayman
1986 Carrera coupe (sold)
1979 911 SC targa (sold)
Old 04-20-2012, 10:46 PM
ratpiper71T's Avatar
Some grease guns or rather the nipple that attaches to the zirk fitting on the bearing- have to be a little loose- that is there's a sheath or tube that screws in and out on the end of the gun-if it's too tight it will look like it seats properly with the zerk, but it doesn't and causes this to happen. You have to loosen and tighten it just enough that there's a little play on the gun end fitting. Not sure if this is the issue but just my observations.
Old 04-21-2012, 06:21 AM
What kind of grease are you using? I have elephant Poly bronze and need to service.
Old 04-18-2017, 05:24 PM
Flyin' blind
LOL! Good point! My suspension rebuild decisions just got easier..... and cheaper!
Thom
89 Coupe
Old 04-18-2017, 07:16 PM
Just got the 87 out of storage and the urethane front bushings are sqeeking like hell.
Old 04-18-2017, 08:16 PM
Same polybronze, same problems greasing the fittings. I get the grease in by putting a lot of pressure against the fitting and pumping one handed. Some still comes out around the fitting, but some also makes it into the bushing. Mostly just a hassle and a mess to clean up.
I'll try grinding down the nozzle.
I also bought a 'heavy duty' nozzle which works better, but is harder to get on and off the nipple.
1986 3.2 to 3.4 conversion
Old 04-19-2017, 10:06 AM
Counterclockwise?
Yes this is a royal pain in the ass!
You need 2 hands as other have stated and a roll of paper towels.
Rod
1986 Carrera
2001 996TT
Old 04-19-2017, 10:17 AM
Sub'd...
'87 Carrera Targa
Old 04-19-2017, 10:20 AM
Retired, finally
SiberianDVM's Avatar
Air powered grease gun.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 04-19-2017, 10:30 AM
Counterclockwise?
I usually grease the fittings with the suspension loaded and then again is a static position with a high quality synthetic grease.
I didn't realize the zerks were removable?
Rod
1986 Carrera
2001 996TT
