both for the 3 & 6 pins. That failure affects the anode voltage rise time of the SCR causing it to conduct while the energy storage capacitor is being charged.
Dave |
board requires replacement of all the components, right? Please! Bosch now provides rebuilt electronics for the pre-2000 Porsches, and they are NOT replacing all the components. Quote:
to protect for all possible failures, e.g. the COP drivers for battery overvoltage or reverse polarity. It's all a matter of cost and the probability of that failure. That's basically the same design strategy used by Bosch when they designed their CDI units. Any system design is approached the same way.
Dave |
Jonny, you should know by now that the old Bosch CDI is just fine!!!!
I personally want to get in my car and DRIVE..... MY Bosch CDI is just fine sitting in a drawer under my workbench. I have Pertronix hall effect system for points and a modern reliable CDI with an "E" coil to drive the plugs and it all runs fine and has never stranded me in 10 years. AND if I had your system it would cosmetically look like a Bosch. [and no red box for me]
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
So dumb question, how do you know when the CDI is not working correctly. My car ran fine when parked last fall but now refuses to run. It kind of fludders runs for 5 seconds backfires and will not rev up. The coil seems to spark when the ign wire is retracted.
Could this indicate a CDI failure, haven't had this touched in my 30 yrs of ownership.
Larry 1971 911T 1983 Envemo, Cabriolet 1989 Carrera Cabriolet |
www.classicretrofit.com |
2. First check that the ignition coil (hopefully not a Bosch silver) wire when placed about 10mm from the engine sheet metal produces a strong blue spark. 3. If the distributor has points, check for their proper setting and clean with emery cloth. 4. Make sure that a good 12 volts is powering the CDI. 5. Try and borrow another CDI form a friend/Pelicanite. 6. Next, use carb cleaner to determine if you have a very lean mixture (backfiring). 7. Bosch CDIs rarely if ever fail because of non-use.
Dave |
We live dangerously. I had no idea these things are prone to failure. I'll carry a spare in frunk.
![]() It seems that the 911 with this module ran well ( perhaps not as good as with proper CDI) but good enough to get you out of a spot. I was going to make a mini loom of 4 wires connecting to the Engine/CDI plug (a 6 pin) following to a common Ignition module like this. That would have got me going & then I would just keep it as a spare in the tool roll. In the end I just got a MSD StreetFire & all is now good. |
