Drive Shaft. Do they ever get replaced? Or break?
A friend's Honda driveshaft sheared today. Just from basic commuting.
How common is it, on any car, for a drive shaft to shear like this? ![]() One guy in the email chain joked that a German version would be 6x the cost. When trying to price one out, I only found boutiques like SierraM, Paragon, and Vertex selling them. I think Pelican may also sell them, but it doesn't seem to be a big thing at all. Then, curious to see where you guys buy a replacement drive shaft, I searched the forum and found almost no threads on drive shaft replacement at all. Like almost no one here has ever replaced one in 15 years of the forum. (just CV joints and boots) What gives?
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 04-12-2017 at 04:16 PM.. |
Porsche axles do not have an intermediate connection like the axle pictured. That said, I've never seen a Porsche axle break, although I've seen CV joints fail, usually because of poor maintenance. Every model that my shop serviced was checked for back and forth motion at every major (15K mile) service. We could tell by the movement when a CV joint needed grease, and we devised a way to use a needle-like tube to introduce grease to each CV joint.
(We made a short piece, maybe 4", of copper tubing with the end hammered almost flat, but leaving a small orifice for grease to pass through, and then curved it to fit against the axle. It's round end attached to our grease gun, and the flattened tip would slide between the axle and the small end of the boot. A few pumps of grease and the boot would start to swell up, which told us it was good to go. If the boot still had a metal clamp we would re-use it. No clamp, no problem; we simply used a high-quality tie rap to seal the boot, and keep the grease inside it). My shop almost never had to replace a CV joint, and we never saw a broken axle. This in a shop that serviced between 3 and 5 911s every day. It's all about maintenance with Porsches. Sadly, I can't offer info regarding the later 996s and 997s, but I don't think reliability is any less when periodic maintenance is done.
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 04-12-2017 at 05:47 PM.. |
abides.
I had to replace a shaft once when the splines on the end developed some rust and spun in the CV.
Graham 1984 Carrera Targa |
6 cylinder symphony
I replaced my half-shafts because my boots were original (from 84), and when I priced out all of the stuff I would need to re-build the CV joints, it was cheaper to buy the 1/2 shafts and just slip them in.
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
That failure is common on honda and acuras. My neighbor had one break the same way. They get rusty under that rubber dampener and it makes a weak spot. Not common on other vehicles
82 SC , 72 914 |
Look at the condition of those boots though...my replacement boots are only 6 years old with less than 20k on them and they look horrible with surface cracks.....those look fantastic on the broken shaft.
1986 3.2 Carrera |
Peter, can you explain how to check for the back forth motion?
Do you still operate your shop?
1986 Bosch Icon Wipers coupe. |
Where did you buy it from?
I got mine here (of course).
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Weird, I wasn't able to find any for sale on PP.
gearhead
See them break all the time on race cars. They break just after the splines end. But these are cars that are lowered which impacts the angle and articulation. Never seen it in a street Porsche. Here's the race solution:
https://swayaway.com/product-category/axles/axle-porsche/
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Digression;
My 911 track car has Ford driveshafts. Used in Escorts at one time. They have a thinner tranny drive flange, so I use bolts with nuts on the backside of the 915 drive Now I have a 3.6L beating on them, so far so good.
1980 911 - Metzger 3.6L 2016 Cayman S |
It's a 914 ...
I ordered qty 2 of 911-332-024-15, this is the part number that I have from my notes anyway, and they do seem to be in stock here on PP as"Complete Axle w/two CV Joints - Boots 911, (1985-89)" same PN with an M60 suffix. Lobro by GKN.
I had >115K on the originals and the PO told me he serviced them once before, but since my boots were torn, and the grease was thrown out, I opted to replace rather than start an icky job which might take me forever and reveal hidden damage in the end. I did keep them for someday when I get really ambitious. All req'd bolts came with them as well. I put them on then asked my wrench to double check my torque a couple hundred miles later when I had her in for state inspection - this was 2014. hth
![]() Ford - P/N# 72GG-4635-BA PS, I also use a Wavetrac LSD (strike two) Used Pirelli race slicks with Formula Vee tire treatment (strike three, your outta here)
I have heard of 911s breaking the axle on race cars with huge sticky tires. Usually after going over a curb and getting the tire in the air with the engine on song and then the tire hits the ground.
On a street car it would be a pretty much not gonna happen thing. At War Bonnet Tech many years ago Porsche AG brought over some real race car parts. They played with a titanium axle design and had one on a table next to a steel one. It was huge difference for the rotational mass. Just too expensive in the gain. The had titanium connecting rods from the car that won at Le Mans. ![]() Some of the door prizes. They kept the drive shaft of titanium and brought it back to Germany.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Under the radar
So, just to be clear, what drive flanges are those? And the Ford CVs match? And the axles are the correct length?
gearhead
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 04-13-2017 at 01:39 PM.. |
The size I used was for a Cosworth Escort of the past It was a plug and play replacement 5 track seasons ago You can really feel the difference in weight
