No running idle
Hello,
I´ve a 3,0 SC euro from 1982, 204 HP and the engine runs normally very fine . But now after rebuilding the exhaust system from a G- to F-Model, the engine has only after warming up no running idle. Means if I stop the car and pull the clutch the engine stop immediately. But after that the engine starts up fine but I´ve to play with the throttel.
Amazing is that the car runs fine before I Change the exhaust, but of course ín the winter break could always something happened.
The only thing I changed on the CIS was that I closed the vacuum line after removing the rest of the air pump (the air pump was removed some years before).
What I´ve done now is to remove, disamble and clean the warm-up regulator. But the WUR was really fine and clean inside and I checked it with a ohmmeter and the value was fine too (but until now I´ve done no pressure check).
I know the next step is to check al the pressures, values and air leaks, but I hope some of the Experts here can locate the problem. So like explained runs fine, take the throttel perfect but has no idle speed if warm.
What do you mean?
996 Carrera 4 Cabrio, 2001, 300 hp, silver, black
911 SC, 1982, 210 hp, white, pascha
912, 1966, 90 hp, light ivory, black
Old 04-20-2017, 09:38 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hi Michael - take a look at the link below. It may help you trouble shoot the idle speed issue. If you have anymore questions, please post a Comment just below the article and we'll do our best to give you specifics.
Porsche 911 Setting the Timing, Dwell and Idle Speed | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
-Dmitry
Old 04-20-2017, 09:51 AM
Hi Dimitry,
thanks for the link. Normally you are right about trouble shoot the idle issues with time setting, Distributor etc.. But these things must be alright.
I guess it´s a part from the CIS which goes wrong and I hope someone can locate it .
Old 04-20-2017, 10:30 AM
T77911S's Avatar
if you removed the air pump it is likely you created an air leak,.
you may have accidentally unplug an air hose or you did not plug something up that needs to be plugged.
exhaust will not effect the idle,at least to the point of not idling.
check to see if your WUR is vacuum controlled. you may have changed something there.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-20-2017, 11:35 AM
Perhaps I´ve an air leak. But I only put the rest of the air pump away and close the vaccum line (see Picture, pos. 31). Or was this wrong and it´s a line for atmosphere?
Old 04-22-2017, 06:55 AM
