LinkBack | Thread Tools | Rate Thread |
3.2 oil leak from radiator and crack studs..solution? (whit engine on board)))
hi/ciao, i look on my 3.2 oil leak from radiator oil..and studs cranckcase (no from superior case...senders oil/pressure ok..thermostat ok...oil seal crackshaft rear new..on occassion chains sostitution)
whit engine on board: 1) if possible remove the radiator oil? 2) the studs/fasterners crackcase if possible disassemble the bolts or pull them more? thanks!GRAZIE
---the difference between insanity and genius is success-- |
Chain fence eating turbo
Are you asking if you can pull the oil cooler off engine with engine still in car?
Yes! ( my enghish its very bad) the engine oil cooler on 3.2 (Need to remove the injection?)
Then there's 2 nuts on the bottom. Should pop off once you remove the large oil hose. |
Forget it. easier to just drop the engine....
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Internal oil cooler seals may be leaking.
Here is an article that includes steps on its removal w/o dropping engine. Porsche 911 Engine Oil Cooler Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
