Originally Posted by 911pcars View Post
Installing an aftermarket shifter isn't the solution to selecting gears. Those products allow more accurate shifting from gear to gear. If you can't shift into a gear, it's either gearbox wear, shift linkage bushing wear and/or basic adjustment.
Sherwood
Thank you Sherwood. I agree with you in that now that all the bushes have been replaced I'm hoping it's a matter of basic adjustment (fine tuning if you will), and I think that was my question in my original post.
Let's hope I can get satisfactory results that way and not have to go down the road of a tranny rebuild.
Old 04-28-2017, 03:49 PM
Yep. Fine tuning, very slight adjustments here and there in directions opposite from the desired direction. It helps to start with reference marks on adjacent parts so you can return to a known start position if needed. The rubber surround under the carrier plate limits lever travel so proper adjustment occurs within a confined window. After an adjustment, the shift lever should be midway in the fore/aft direction (lever vertical) in Neutral so there's sufficient travel to fully engage 1-3-5 in the fore direction and 2-4-R in the aft direction.
Old 04-28-2017, 04:51 PM
Brew Master
cabmandone's Avatar
For what it's worth, I have driven my brother's car with the Wevo shifter and a Wevo coupler. My car has the Seine gate shift kit and I have brass bushings in the coupler. My brother and I both think my less expensive setup feels every bit as good as his Wevo setup.
Old 04-28-2017, 04:52 PM
joefrantz's Avatar
I agree with Cabmando on the couplers.
I've had both a Wevo coupler and a stock coupler with brass bushings.
I found them indistinguishable.
Can't comment on the shifter mechanisms - no experience with either.
Another discussion here:
915 shifter linkage play after replacing bushing, video attached
Joe Frantz
73 911 T
Old 04-28-2017, 08:10 PM
