Let's hope I can get satisfactory results that way and not have to go down the road of a tranny rebuild. |
Yep. Fine tuning, very slight adjustments here and there in directions opposite from the desired direction. It helps to start with reference marks on adjacent parts so you can return to a known start position if needed. The rubber surround under the carrier plate limits lever travel so proper adjustment occurs within a confined window. After an adjustment, the shift lever should be midway in the fore/aft direction (lever vertical) in Neutral so there's sufficient travel to fully engage 1-3-5 in the fore direction and 2-4-R in the aft direction.
Brew Master
For what it's worth, I have driven my brother's car with the Wevo shifter and a Wevo coupler. My car has the Seine gate shift kit and I have brass bushings in the coupler. My brother and I both think my less expensive setup feels every bit as good as his Wevo setup.
I agree with Cabmando on the couplers.
I've had both a Wevo coupler and a stock coupler with brass bushings. I found them indistinguishable. Can't comment on the shifter mechanisms - no experience with either. Another discussion here: 915 shifter linkage play after replacing bushing, video attached
Joe Frantz 73 911 T Last edited by joefrantz; 04-28-2017 at 07:14 PM.. |
Thread Tools | |
Rate This Thread | |
