-   -   Help car stays running after pulling key (http://forums.pelicanparts.com/porsche-911-technical-forum/954848-help-car-stays-running-after-pulling-key.html)
riverstonefly 04-27-2017 07:41 PM
Ok fellas I just had the retro fuse relays from our host installed today by a reputable Auto electric shop and after picking the car up everything was working fine. I decided to take a quick drive after work this evening but only made it a 1/4 mile when the car just shut off! I pulled into a vacant lot and it fired right up so I figured Id head back to the garage and upon arrival I turned the ignition switch off and pulled the key out but the car stayed running! The only way to shut the car off was by popping the clutch but the pump and alt light stay on so I disconnected the battery.
Please help
JR
timmy2 04-27-2017 09:47 PM
What year car? Do you mean the replacement fuse panel with headlight relays?
It sounds like maybe the shop screwed something up or your ignition switch electrical has failed.
dg567 04-27-2017 10:24 PM
By any chance is your foot on the brake?
riverstonefly 04-27-2017 10:37 PM
1980 and yes the retro ato fuse relay kits sold by our host.
https://uploads.tapatalk-cdn.com/201...f95f06f675.jpg
Sent from my XT1650 using Tapatalk
riverstonefly 04-27-2017 10:38 PM
To be honest I can't recall?
dg567 04-28-2017 06:00 AM
Same thing happened to me - but if I took my foot off the brake the car would shut off with the key out. Took me a while to figure this out because you're used to having your foot on the. Take when the car is parked. There was a bad ground in one of my front turn signal housings. Which would also illuminate when the brakes were pressed. I cleaned up the connections in my front driver turn signal housing and made sure everything was grounddd correctly and it fixed my issue! Try it in the garage with the lights off so you can see if the turn signal illuminates.
Jonny H 04-28-2017 07:12 AM
There are no reported issues with our fuse panels and we have over 300 units installed across all model years.
It does sound like either a wiring error or a ground issue.
riverstonefly 04-28-2017 09:46 AM
Tried the brake and car still stays running, also my blower is no longer working.
riverstonefly 04-28-2017 09:48 AM
I have complete confidence in the product sir just asking if anyone else experience the same issue after the swap, hoping it's something simple.
Jr
riverstonefly 04-28-2017 06:21 PM
Update
https://uploads.tapatalk-cdn.com/201...f6af0152e9.jpg
It's all good
rbogh901 04-28-2017 08:35 PM
Originally Posted by riverstonefly (Post 9568734)
Update
It's all good
And so it was a bumped ground during fuse bank install or...? Is the watch a clue?
rattlsnak 04-30-2017 07:33 AM
Pull the handbrake up and see it if cuts off.
ap997s 04-30-2017 08:07 AM
So what made it 'All good'? Was it 'FM'?
rbogh901 04-30-2017 11:44 AM
Would that indicate a grounding problem in the emergency brake light circuit?
stevej37 04-30-2017 11:52 AM
Sure would be nice to hear what the answer to the prob was.
rattlsnak 04-30-2017 02:40 PM
Originally Posted by rbogh901 (Post 9570346)
With that indicate a grounding problem in the emergency brake light circuit?
Diode.. See this thread..
http://forums.pelicanparts.com/porsche-911-technical-forum/922938-weird-76-electrical-issue-headlights-engine-wont-turn-off-speedo-light-braking.html
86 911 Targa 04-30-2017 02:44 PM
Issue.
I agree!!
Nothing worse than not posting the resolution
to one's posted issue......
Gerry
rbogh901 05-01-2017 10:13 AM
Thanks rattlesnake. I tried to chase this in my 1977 but couldn't find anything that looked like a diode holder in the dash behind the speedo. Also, my fuel pump keeps running so must be on that circuit as well. Did 77 have a diode in their Dash wiring and if so where do you look?
rattlsnak 05-02-2017 05:16 PM
I have looked for it on a few cars and have never found it. Doesn't matter anyway, if it's bad it just acts like a normal piece of wire so to speak. You can just splice in a new one behind the gauges.
RSBob 05-02-2017 08:50 PM
Reading between the arm hairs, I believe the skullified knife and maybe the watch were lodged into the fuse panel creating the issues. Or maybe it was the key fob, or a comet. Definitely X-files stuff.
