QUICKJACK lift for a 911 (or 914)!
Just thought you guys/gals might enjoy checking out a new type of car lift that I've been testing. It's a portable lift that you can easily take with to the track or use at home. Anyway, those are my 914's in the pics.
What I've been testing (QUICKJACK by Ranger Products)! - The Garage Journal Board
Old 09-24-2013, 12:39 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Post Pics? No I don't want to register on another site to see them.
Who Will Live... Will See
Old 09-24-2013, 01:07 AM
Lift
Concur.........................don't want to register to another site to see the pictures!!!!!!!!!!!!!
Old 09-24-2013, 04:23 AM
The link below, provides a full description of the product, as well as photos and a video.
Racecar Pit Lift Jacking System - QuickJack
Old 09-24-2013, 04:57 AM
Lift
Without having to fill out the form..............cost?.............$$$$$$$
Old 09-24-2013, 05:25 AM
Jnikic's Avatar
Looks like its right about $1k - not so bad ...
Ranger 5175185 3,500 Lb. Capacity QuickJack™
Anyone with real world experience?
78 911 Coupe :: E Prepared racecar :: Stock 3.0 :: Steel widebody :: 930 brakes
78 911 Targa RSR backdate :: 3.2L :: 10.5:1 Wossner pistons / Mahle cylinders :: Twin plug crankfire ignition :: 46mm PMO
Old 09-24-2013, 05:59 AM
How do you avoid getting hydraulic oil everywhere when taking it apart?
1982 911SC Wine Red Metallic
OMG I love this car!
Old 09-24-2013, 07:11 AM
Elombard's Avatar
$1000? That does not look like $1000 worth of kit. I wonder if harbor freight will do a version for $250 that lasts 48 months :-) I wonder what is patentable? It looks very simple, in fact I am suprised it has not been done before.....I want one!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 09-24-2013, 09:08 AM
lift
When compared to a 6000# scissor lift from Harbor (China) Freight..........for around $1600.................seems a little costly.......................but the scissor lift is not portable
Old 09-24-2013, 09:17 AM
175K911's Avatar
I actually like the idea. But my concern is the 3500# load rating. For a lot of cars that leaves no margin for error. Great for a 2400# track car but not any current model Porsche.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 09-24-2013, 09:34 AM
Elombard's Avatar
I have not read all of the info but how does it deal with slightly un-even surfaces? I assume the control box keeps it level side to side?
Old 09-24-2013, 09:47 AM
ROW '78 911 Targa
timmy2's Avatar
17" lifting height. Won't be using it to drop the engine....
Old 09-24-2013, 10:08 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Take a look at picture #5 in the bestbuyauto link Ranger 5175185 3,500 Lb. Capacity QuickJack™ They're called quick-connects. Similar to Staubli style connectors used in racing. Pretty trick stuff and perfect application for these connectors.
Ranger makes quality stuff. I think it's a good value. Plus it beats the heck out of the scissor lifts that weigh 12 bazillion pounds like the aforementioned Harbor Freight rig. I would love to have one of these in the garage for basic service on the racecar. Stows away nicely in the corner of the garage when not in use.
Kevin L
'86 Carrera "Larry"
Old 09-24-2013, 11:36 AM
The QuickJack can lift pretty much any Porsche except the Cayenne and the Panamera, since their curb weight exceeds 3,500 pounds. You'll want to wait until next year and then get the 5K capacity QuickJack so you can lift those too,
To answer the other question you definitely want to be on an even surface (that's safer anyway). It's fine if its slightly sloped too. The QuickJack does ensure that both ramps lift and lower at the same time.
Old 09-24-2013, 02:21 PM
Navin Johnson
TimT's Avatar
Why not?
You would just have to raise and lower in stages, install blocking/jack stands as needed etc.
I could easily see raising the car, placing a dolly below the engine..
Disconnect everything attached to the engine/tranny...
Lower car onto dolly
Then raise the car.... engine stays on dolly.. then jack stands, raise lower car enough to pull dolly from beneath etc...
wash/rinse/repeat.....
I bet it could be done with few cycles..
This past summer we jacked up a railroad bridge 1.5 feet that weighed around 500 ton using jacks that only had 1 in stroke...
'69 911 GT-5
'75 914 GT-3
and others
Old 09-24-2013, 02:25 PM
Algernon - I can assure you that the quick disconnects don't leak a drop when you disconnect them. However, if you take your time and go really slow when reconnecting them, like a friend of mine did, then yes you will leak a little fluid. The trick is to connect and disconnect them quickly so that the internal parts don't get to stay in a partially open state for too long. Also these are amazingly easy to connect and disconnect - much easier than air lines.
Finally keep in mind that you're never going to be disconnecting the lines while there is pressure in them. You only want to disconnect the lines after you have the QuickJack fully collapsed.
Old 09-24-2013, 02:32 PM
GOM (Grumpy Old Man)
Busta Rib's Avatar
Interesting product and could be compelling for the DIYer. Thanks for sharing.
Old 09-24-2013, 02:33 PM
+1
Old 09-24-2013, 02:37 PM
964
Mr.Alex's Avatar
Certainly easier than getting liftbars in place, which is what I currently use to get my car in the air. Perhaps one day on sale...
Guards Red 964
Old 09-24-2013, 03:41 PM
175K911's Avatar
5k would be ideal. A 997 4S is 3500 lb so no margin for error like a full tank of fuel.
I do like it though. Wonder if the hydraulic lines are tough enough to drive over. I need to check the specs to see if the collapsed height is listed. Would be cool to leave it on the floor in the garage, push the pieces inboard far enough to back out of the garage and not have to pull them out and store off to the side. Pull the car back in, reach under and pull the lift pieces back out into place.
Do you have one of these in Plainfield? KTL and I may need to come check it out.
Ed
Old 09-24-2013, 04:03 PM
