Originally Posted by Sooner or later View Post
Waiting on approval to get a few bad pics posted.
Just doing some research it seems that all the suspension rubber will need replaced. Calipers and master cyl could also be toast.
And then the fuel system. If CIS needs serious work I would consider a set of PMO carbs. And SSI. And while we are in there...
It does have the pop off valve and updated chain tensioner. And a boatload of records. They drove it about 3k a year. Changed the oil in the spring and then in the fall when they stored it.
I have done lots of work on my old Mutangs (65 K code fastback being one) but at 62 I'll let others do the work.
Seriously think about Electronics Fuel Injection (EFI) if the CIS needs too much work. Many folks here have done it, seems like a better route than carbs these days.
Rutager West
Old 05-05-2017, 02:54 PM
Thanks. Anything is possiible
Old 05-05-2017, 03:04 PM
I don't need a loan. It is damn solid appearance wise. No type of rust anywhere. Hell, it doesn't have a door ding. I think it has a 930 steering wheel.
If it is worth 35 I wouldn't feel bad about dropping 30 into it to get it closer to what I might want.
Thanks for all the replies.
its not worth $35 if its mint
1975 Carrera #116 3.6 guards red sold
1980 911sc Talbot Yellow got back!! 1978 911sc 3.6 Sold
1996 993 tt white Sold. 1997 993tt red Sold 1986 930 sold
1986 491 Prussian blue sold 2002 tt white sold
1996 993tt adventurine/gray 1987 carrera with a 3.8
Old 05-05-2017, 03:06 PM
Originally Posted by sugarwood View Post
It's doubtful you'll need to drop $30k to get it running.
Let us know the quote and update this thread if you do down the repair journey!
Will do. I am in no hurry. Figure out what I am doing and THEN go full speed ahead.
Old 05-05-2017, 03:07 PM
I won't call it mint but it has to be damn close after a good detailing.
Is that higher or lower than $35?
Old 05-05-2017, 03:10 PM
Targa top. Only wiped it down with water.
Old 05-05-2017, 03:17 PM
Old 05-05-2017, 03:18 PM
Old 05-05-2017, 03:20 PM
TibetanT's Avatar
That does look like the original Targa Top since it looks like mine. I noticed the handles are missing, but they are hopefully in the glove compartment.
Your Fuchs look as though they were refurbished which is nice, and the driver's side has some aluminum pedals so this car was loved. Yeap, your entire emissions system was removed and they, PO, did update to the Pressure-fed tensioners. Engine bay looks to be in good shape, and that does look like a 930 steering wheel.
Good for you!
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 05-05-2017, 04:31 PM
That car is easily worth twice, probably closer to 3x what you paid for it. Great score!!! Fix the studs and fuel system and drive it like you stole it! You won't regret it!!!
Old 05-05-2017, 05:03 PM
sugarwood's Avatar
Here is a motor
1984 Porsche 911 1984 PORSCHE 911 Carrera 3.2 Engine Long Block
1986 Bosch Icon Wipers coupe.
Old 05-06-2017, 05:58 AM
Cars and Cappuccino
tdw28210's Avatar
That car has several signs of being owned by a Porsche enthusiast at some point in its life. Maybe not the last PO, but at SOME point. Casual owners don't put in aftermarket pedals, a steering wheel and buy a second set of wheels. I think there is a decent chance this thing has had top end work done already.
I'd do a cold compression test. If that looks decent I'd change the oil, (don't top it off) drain the fuel tank add some fresh gas, put a battery on it and see what happens.
Even if it DOES need top end work, it was an awesome buy. Congrats.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 05-06-2017, 06:17 AM
If the engine's shot/requires a lot of $$$, consider transplanting in a later 3.2L (straightforward) or 3.6L (not as straightforward) engine --
Old 05-06-2017, 06:49 AM
I appreciate all the help and suggestions.
I will try to get it cleaned up this week and get some better pictures.
Old 05-06-2017, 09:24 AM
I live in Tulsa, you need to call Tom Charlesworth. He can get you going and knows his stuff you got a fantastic deal. Tom is also very reasonable and easy to deal with, he did my transmission for 1400, which is unheard of, that was with the engine drop. I bought the parts for the job and he did all the work, oh and he also put on my SSI and back dated my heat for that price.
Take it to him.
Old 05-06-2017, 12:00 PM
Senior Member
Jdub's Avatar
If I were you I would follow through with your instincts and sell it on, preferably to someone on this BBS.
Good luck!
'78 Targa in Minerva Blue
Old 05-06-2017, 12:07 PM
Take it to him.
Thanks! I will give him a call and get his take.
Old 05-06-2017, 01:58 PM
Starting the clean up and foiund thiis. A granite plaque. Tweeks Funfest Judges Choice June 7/8,? 2003.
I should have better pictures later this week.,
Old 05-08-2017, 09:36 AM
A few more pics and then a question ort two. I just dusted it off and then a little water and chamois.
Old 05-15-2017, 10:21 AM
Old 05-15-2017, 10:24 AM
