86 Carrera Calipers on 79 SC?
I happen by chance to get a brand new pair of front Carrera 3.2 Calipers.
Correct me if I'm wrong but I recall that the mounting bore is the same as to those of the SC M Caliperm (?). I have Bilstein Turbo struts front. Did a search but could'nt find exacly this. All I need is the pads and the (bigger) Carrera rotors (which will give me more cooled mass), right? Is there a different fluid line too? Thanks edit: set up as is now (bone stock SC brake system) - new master cylinder 2016 - new Zimmerman drilled rotors front/rear 2015 - new calipers front/rear 2015 - new steelfelx brake lines (4x) 2015 - new pads Ate regular 2016 (the EBC greenstuff did not harmonize on Zimmermann) - flushed brake líne system (regular DOT4) 2016
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 05-09-2017 at 06:24 AM.. |
You've got it right-just bolt em on and go-or stop
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
I assume you track the car? otherwise such a change is for aesthetics. Perhaps it would be worthwhile to look up brake cooling - such 993 air scoops.
Thanks.
I think about it as the Carrera caliper has wider pistons. Together with the larger rotors it will be enough improvement without going sky high. I take this as a GO :
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 05-09-2017 at 06:27 AM.. |
Not as it seems
adding the front Carreras and a cooling set up was all I ever did to my spec racer brakes running the OC SC rears & good pads. worked well.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
The Carrera caliper is the same as the SC caliper - except that there is a spacer added in the caliper that allows the use of a wider rotor.
I have the same brakes. I just stared this thread as I cant find the answer as to their bias/balance; Brake Bias - Wide "A" with M rears? |
at leas what I saw is that the pistons pad-touching edge is wider in design. no? Quote:
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Pistons are exactly the same, the only difference as mentioned is the Carrera calipers have a 4mm spacer, nothing else is different. The mounting holes, brake line connections, piston bore, piston size, internal fluid routing and pad size are all 100% exactly the same. The 2 side castings are the exact same part.
Going to the Carrera setup will just give you some extra thermal mass. not worth spending money on, but if you got a good deal (meaning, nearly free) on the wider equipment then there's no reason to not run it.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Ok, so new rotors only.
Here is quote from Bill V. I hope he does not mine my quoting him. He has been a source of information on brakes for a long time on this board. "A small brake upgrade for SC or earlier Carrera is to use the wide A caliper and rotor w/ stock rear M caliper and rotor. This retains the excellent 9 bias seen in all 911s through '83. Similarly '84 can leave their front alone and change the rear to the regular M rear using the regular M 20mm rear rotor instead of the wider 3.2 Carrera 24mm rear rotor and wide M. This gives the car excellent bias once the stock p/v is removed." |
Do I understand correctly:
- put actual SC fronts to rear - put Carrera up front ?
Two additional notes front M and rear M use the same pads but are otherwise quite different calipers There is almost never any good reason to put fronts in back
Thanks Bill!
