I usually set off pretty quickly. Certainly in less than a minute. I find if I set off immediately though, then CIS hasn't warmed up and I get some hesitancy for the first block. When I let it "warm up" in the driveway for maybe 30 seconds, I don't get that hesitancy usually. So you're saying that on cold starts, and low oil pressure the parts aren't getting enough oil? My brother likes to idle his car before taking off sometimes for a few minutes, but I've ready its not the best idea.
1983 SC Coupe Chiffon White 3.0 rebuilt by me 9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch. |
Plugs were selected by my mechanic, a knowledgeable guy. I haven't pulled them since the rebuild 2500 miles ago. But I will. I did do all the CIS tests and ran an AFR meter in the tail pipe after the rebuild to get my AF mix dialed in. So if fuel pressure has built up between drives, how does letting the pump run for 5 seconds relieve this? Does it equalize in the FD and return to tank?
Either way, once she's on, I'm not shutting her down just to save some idle time. Either this Germanic machine can take it or I'm not interested.
79' 911sc |
you can run the pump before a cold start, see if that helps with first start up.
I understand that with the first start it runs bad but if you shut it off then restart it starts fine, correct?
Yep, starts immediately every time. Start immediately on the restart too.
Ok. I just did this. It fired right up and idled immediately at 1000rpm. But that doesn't tell me much, since it does this on its own maybe 30% of the time. I still haven't tested my TTS, but given that the car starts 100% of the time on the first crank, I think I'm getting cold start injection just fine.
