Do these Engine bushings look stock? Also what exhaust?
Hey guys, couple of questions about this car- its a 77 Targa here are pics underneath, the little rods on each side of the engine, ( i think they are called engine bushings?) do these look stock? Also does this car have stainless steel exhaust? it looks stock but sounds really good and diff from any other 77 i've had..I'm a bit new to the air cooled so need some help here..thanks
I've annonated the part i'm talking about, its those rods coming out of each side of the engine case ![]() ![]()
Member 911 Anonymous
Not sure what "rod/bushings" your are talking about, maybe circle them for us?
As far as exhaust, put a magnet to it compared to steel part and you will quickly tell
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Look at his picture! He circled the oil return tubes. get it?
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Oil return tubes.
Bob B |
Mighty Meatlocker Turbo
The oil return tubes you circled are not stock - they were installed at some point when the o-rings for the original, solid tubes were leaking and replaced (the collapsible tubes allow o-ring replacement without having to remove, and partially disassemble the engine's top end).
Also regarding the exhaust question - the header portions (the sections that are also in your circles) are pieces that were used to replace the original thermal reactors (not stock) . . . not sure if you were asking about those, however. |
Thermal reactors and 2.7 liter magnesium engines were a bad combo, caused excessive heat and engine problems. Good that they were removed -- how many blades does your engine fan have? Believe these cars came with a 5 blade fan (which didn't cool as well as the 11 blade fan used before and after) -- replacing the 5 blade fan with a 11 blade fan was another good preventative update. As for the oil return tubes, no, since the collapsable oil return tubes can be installed without removing the heads/engine/etc., their existence does not suggest or confirm that a top end was (or was not) done. |
Often the extra sound comes from the three pipes weld breaking or cracking right where they come together.
Bruce |
Crotchety Old Bastard
Lot of performance left on the table with that exhaust system. It is already set up for dual inlet so replace those awful exchangers with headers or early exchangers.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Hi Tarek..looks like a nice car.Someone has taking care of it well.The (aluminium) oil return tubes were introduced back in the 1980`s by performance products in Van Nuys California today known as Automotion. It was a cheaper version those days for the original factory oil return tubes.
You do not need to do anything with them now.Once they will be leaking get the original tubes .Not to expensive these days. The muffler i remember had a nice deep sound as it was on my 77 911S before i moved to Europe So enjoy it ,....nice 911 Ivan |
I would highly recommend replacing the heatexchangers at a minimum with something that is equal length ssis, rarlyl8, or the likes.. Wish I could help you but only make 914-6 parts..
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
