88 Master brake Pic needed
Hi
I need a pic of the master brake area on an hyd. clutch 911. I want to see where the factory routes the feed line for the clutch. Can anyone help me out?
TIA
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 01-25-2003, 05:10 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Here you go Dean.
Kevin L
'86 Carrera "Larry"
Old 01-25-2003, 11:17 AM
Here is a pic of it off the car.
Old 01-25-2003, 01:27 PM
There is no line for the clutch off the MC. It must come off the rear brake line under the car.
Old 01-25-2003, 01:28 PM
Bill Verburg's Avatar
Here's a diagram;
The feed line #9 comes off the side of the brake fluid resivoir, the blue line in KTL's pic.
Bill Verburg
Old 01-25-2003, 03:22 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Just for clarity's sake, Bill's diagram shows a separate master cylinder. NOT the brake master cylinder. The clutch master cylinder gets its supply of fluid from the brake fluid reservior, and the cylinder itself is located within the pedal cluster.
The brake pressure lines and clutch pressure lines are two separate systems and therefore do not share anything except their fluid supply source.
Kevin L
'86 Carrera "Larry"
Old 01-25-2003, 03:59 PM
Sorry, if that wasn't clear.
Bill Verburg
Old 01-25-2003, 04:05 PM
Yes I get it. Kevin's pic shows were the feed line goes. That is what I needed.
Thanks again
Dean
Old 01-25-2003, 04:14 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Plenty clear to me Bill. I've looked at that diagram a bunch of times. We know the layout, but you never know what others may think.
The mention of the clutch line coming off the rear brake line got me to thinking that there might be some confusion. That's all.
Kevin L
'86 Carrera "Larry"
I never know when to be long winded and when not to.
the short, bandwidth conserving ans should be "the blue line in KTl 's pic"
This medium is soo frustrating at times, thats why I like picture. You should read one that I have been trying to participate in over on Rennlist, people just don't read or refuse to understand sometimes, I guess my lousy composition doesn't help.
Bill Verburg
Old 01-25-2003, 04:28 PM
