SC suun roof seal replacement
I've just received a new (front) sun roof seal for my SC without any instructions.
Is the new seal held in place with a simple adhesive, such as contact cement or is there a more elaborate way of doing this?
Thx,
Hugh
Old 05-15-2017, 12:00 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
contact cement. Half the seal is attached to the roof of the car the other half to the moving sunroof. lots of info on the board here.
Chris
73 E
Old 05-15-2017, 02:07 PM
Thanks Chris. I did a bit more searching and saw where a 3M product was recommended, so I may go that way.
The old seal (attached to the body) pulled off quite easily and I don't think contact cement would have been that easy but I think it (contact cement) would give a more secure bond.
I may initially try the 3M product but if I'm not happy I'll try contact cement.
Hugh
Old 05-15-2017, 02:45 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hi Hugh - if you're looking for a guide and info on installation, take a look at the link below. If you have any questions, feel free to post a Comment just below the article and we'll do our best to give you specifics. Best of luck!
Porsche 911 Sunroof Repair | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 05-15-2017, 04:58 PM
Undocumented User
McLaren-TAG's Avatar
Use the 3M stuff sparingly, let it dry and wipe off any excess immediately, it's easily removed with alcohol.
Old 05-15-2017, 05:03 PM
Discseven's Avatar
Prep the surface super clean or the best adhesive will fail. There's a technique for cutting the internal rubber of the seal at the dive downs. Got to get this right so the front and rear seal meet nicely.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-16-2017, 05:58 AM
Thanks guys, I think I got it right. Time will tell.
Old 05-16-2017, 02:01 PM
