Ambitious Outsider
H4 Bulb suggestions w/relay upgrade
Hi all, i just finished installing the headlight relay upgrade kit, now it's time to replace the bulbs for a brighter pair- what are you using with the relay upgrade? after the upgrade the brightness of my current bulbs did not increase, they still look the same.
thanks!
1988 3.2 Cab 2005 997.1 C2S |
Rescuer of old cars
Phillips 80/100 in mine.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Ambitious Outsider
Thanks Arne, will look tomorrow. definitely will need the 100w h4.
Banned but not out, yet..
An air cooled refrigerator. ‘Mein Teil’ |
Get a set of these Phillips X-treme Vision +130 bulbs, they are fantastic!
I had tried 100W bulbs but I like these better as they project further. The folks on the CandlePower forum have tried them all and say these are the best by far. They don't recommend the 80/100 as they have a much shorter life and don't project or focus as precisely. Try um,you'll love um! https://www.amazon.com/Philips-X-treme-Vision-Headlight-Bulbs/dp/B00QJWUPC6
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 05-15-2017 at 08:12 PM.. |
Slippery Slope Victim
Mike˛ 1985 M491 |
Ambitious Outsider
Thanks guys- appreciate the suggestions!
Dial 911
Hi...Is the light white, or do they have a blueish tinge?.. Thanks in advance!
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
a very white 3700K versus the standard 3500K light temperature which looks a little more yellow. But no, they don't look like the "ricer" blue bulbs. The high beam is very precisley focused for far view without a "near field" bright splash of light which spoils your far view. The near field bright splash is the problem with the ultra high watt 80/100 bulbs (besides being technically illegal). With the ultra high lumens of the 100w bulbs you actually have worse far view as your pupils contract due to the very bright light up close.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Vintage Owner
Don't the 100w bulbs also cause trouble with the heat to the connector? I remember reading something about ceramic connectors to deal with the excess heat.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Ambitious Outsider
Yes I believe it would be wise to use ceramic connectors if running 100w bulbs. Especially with our old cars. So far everything I've read has been extremely positive for the Phillips +130. I'm leaning in this direction, and for $25 bucks for the pair, you can't go wrong. PIAA 100w rally bulbs are almost a $100. Then the extra cost for the ceramic connector.
Dial 911
Thanks 'uwanna' for your detailed info!..They certainly seem to be the way to go for me - I'm also going to purchase a pair of them.
abides.
High resistance in loose and corroded original terminals is another reason to replace the connectors.
Graham 1984 Carrera Targa |
3.4 Bigger is better
I put in Phillips Gen 7 LED bulbs. They take 35 watts and are 4000 lumens. They have been great. I just need to get the alignment right. No heat issues and love the color of the light.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
High wattage bulbs
Don't overload the amperage rating of the relays. If you have 2 bulbs (left and right) running thru a 20 amp capacity relay then the max would be 120 watts for each bulb and that would be right on the max capacity. If you are going to use 130 (or higher) watt bulbs then you will need 30 amp capacity relays and main fuses. Don't burn your car down just to get a brighter light!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Dial 911
Thanks for the info Fred!
Ambitious Outsider
Update- got the Phillips x-treme vision bulbs in, had the car out last night with my Wife who knows how bad the lighting can be and we were both blown away with the new setup! I just need to set the beam's a bit lower, I noticed they were a little on the high side. Thanks guys
Dial 911
One main site that is selling them is from eastern Europe, and another one is from the UK...The latters price is right for Canada but it takes up to 10 days to receive them http://www.carbulbsdirect.com/ca/product/philips-xtreme-vision-130-h4-twinprice is
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 05-24-2017 at 06:36 PM.. |
Ambitious Outsider
Got mine on Amazon- took 3 days. One day to get back in stock and then 2 days for shipping, Im in the midwest. Pepboys only has x-treme +50, +75 and +100 no dice on the +130's.
