Ambitious Outsider
sabeo.m's Avatar
H4 Bulb suggestions w/relay upgrade
Hi all, i just finished installing the headlight relay upgrade kit, now it's time to replace the bulbs for a brighter pair- what are you using with the relay upgrade? after the upgrade the brightness of my current bulbs did not increase, they still look the same.
thanks!
1988 3.2 Cab
2005 997.1 C2S
Old 05-15-2017, 06:09 PM
Rescuer of old cars
Arne2's Avatar
Phillips 80/100 in mine.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 05-15-2017, 06:38 PM
Ambitious Outsider
sabeo.m's Avatar
Thanks Arne, will look tomorrow. definitely will need the 100w h4.
1988 3.2 Cab
2005 997.1 C2S
Old 05-15-2017, 07:01 PM
Banned but not out, yet..
RSBob's Avatar
Originally Posted by arne2 View Post
phillips 80/100 in mine.
+1
Old 05-15-2017, 07:36 PM
Get a set of these Phillips X-treme Vision +130 bulbs, they are fantastic!
I had tried 100W bulbs but I like these better as they project further. The folks on the CandlePower forum have tried them all and say these are the best by far. They don't recommend the 80/100 as they have a much shorter life and don't project or focus as precisely. Try um,you'll love um!
https://www.amazon.com/Philips-X-treme-Vision-Headlight-Bulbs/dp/B00QJWUPC6
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-15-2017, 07:40 PM
Slippery Slope Victim
NY65912's Avatar
Originally Posted by uwanna View Post
get a set of these phillips x-treme vision +130 bulbs, they are fantastic!
I had tried 100w bulbs but i like these better as they project further. The folks on the candlepower forum have tried them all and say these are the best by far. They don't recommend the 80/100 as they have a much shorter life and don't project or focus as precisely. Try um,you'll love um!
https://www.amazon.com/philips-x-treme-vision-headlight-bulbs/dp/b00qjwupc6
+1
Mike˛
1985 M491
Old 05-16-2017, 02:21 AM
Ambitious Outsider
sabeo.m's Avatar
Thanks guys- appreciate the suggestions!
1988 3.2 Cab
2005 997.1 C2S
Old 05-16-2017, 05:10 AM
Dial 911
A horse with no name's Avatar
Hi...Is the light white, or do they have a blueish tinge?..
Thanks in advance!
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 05-16-2017, 11:12 AM
Thanks in advance!
The light is white, they add just a tinge blue to the bulb to make the light
a very white 3700K versus the standard 3500K light temperature which looks a little more yellow. But no, they don't look like the "ricer" blue bulbs.
The high beam is very precisley focused for far view without a "near field" bright splash
of light which spoils your far view. The near field bright splash is the problem with the
ultra high watt 80/100 bulbs (besides being technically illegal). With the ultra high lumens of the 100w bulbs you actually have worse far view as your pupils contract
due to the very bright light up close.
Old 05-16-2017, 11:37 AM
Vintage Owner
Jack Stands's Avatar
Don't the 100w bulbs also cause trouble with the heat to the connector? I remember reading something about ceramic connectors to deal with the excess heat.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 05-16-2017, 12:15 PM
Ambitious Outsider
sabeo.m's Avatar
Yes I believe it would be wise to use ceramic connectors if running 100w bulbs. Especially with our old cars. So far everything I've read has been extremely positive for the Phillips +130. I'm leaning in this direction, and for $25 bucks for the pair, you can't go wrong. PIAA 100w rally bulbs are almost a $100. Then the extra cost for the ceramic connector.
1988 3.2 Cab
2005 997.1 C2S
Old 05-16-2017, 12:21 PM
Dial 911
Thumbs up
Thanks 'uwanna' for your detailed info!..They certainly seem to be the way to go for me - I'm also going to purchase a pair of them.
Cheers!
Leonardo Da Vinci
Old 05-16-2017, 12:24 PM
gtc gtc is online now
abides.
gtc's Avatar
High resistance in loose and corroded original terminals is another reason to replace the connectors.
Graham
1984 Carrera Targa
Old 05-16-2017, 03:24 PM
3.4 Bigger is better
88-diamondblue's Avatar
I put in Phillips Gen 7 LED bulbs. They take 35 watts and are 4000 lumens. They have been great. I just need to get the alignment right. No heat issues and love the color of the light.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 05-16-2017, 04:12 PM
fred cook's Avatar
High wattage bulbs
Don't overload the amperage rating of the relays. If you have 2 bulbs (left and right) running thru a 20 amp capacity relay then the max would be 120 watts for each bulb and that would be right on the max capacity. If you are going to use 130 (or higher) watt bulbs then you will need 30 amp capacity relays and main fuses. Don't burn your car down just to get a brighter light!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-16-2017, 04:21 PM
Dial 911
Thumbs up
Thanks for the info Fred!
Cheers!
Leonardo Da Vinci
Old 05-18-2017, 04:47 PM
Ambitious Outsider
sabeo.m's Avatar
Update- got the Phillips x-treme vision bulbs in, had the car out last night with my Wife who knows how bad the lighting can be and we were both blown away with the new setup! I just need to set the beam's a bit lower, I noticed they were a little on the high side. Thanks guys
1988 3.2 Cab
2005 997.1 C2S
Old 05-23-2017, 05:18 PM
Dial 911
Hi...Where BTW were you able purchase your Philips Extreme Vision +130 H4's?.. Amazon's US sites on the West Coast continue to be down...Our local shops only handle the Extreme Vision 100's.
One main site that is selling them is from eastern Europe, and another one is from the UK...The latters price is right for Canada but it takes up to 10 days to receive them
http://www.carbulbsdirect.com/ca/product/philips-xtreme-vision-130-h4-twinprice is
Cheers!
Leonardo Da Vinci
Old 05-24-2017, 06:34 PM
Ambitious Outsider
sabeo.m's Avatar
Got mine on Amazon- took 3 days. One day to get back in stock and then 2 days for shipping, Im in the midwest. Pepboys only has x-treme +50, +75 and +100 no dice on the +130's.
1988 3.2 Cab
2005 997.1 C2S
Old 05-24-2017, 07:17 PM
Check here:
Old 05-25-2017, 12:37 AM
