911 SC oil line thermostat
If the threads on the oil line thermostat are decent (not buggered up from steel oil line removal), what else could be wrong with it? The thermostat itself is removable, isn't it? Would it be identical to the thermostat on the front of the case? Do they typically go bad?
Speedo
Old 05-29-2017, 01:16 PM
The thermostat element in the engine-mounted unit is the same as the external one in the fender well. There is a test for that unit that involved boiling the unit on the stove and checking for opening and closing temperatures. Use SEARCH and focus on the name of Boyt911SC -- he did the test and posted it. Also name KTL comments often in threads concerning the thermostats.
Old 05-29-2017, 03:26 PM
Hilbilly Deluxe
emcon5's Avatar
Here is the thread: Thermostat Valve Opening Test....
82 911SC Coupe
GTI Cup #43
Old 05-29-2017, 08:41 PM
Auxiliary thermostat tests.........
See post #28 below:
Outside Thermostat
Tony
Old 05-29-2017, 09:49 PM
