Wiring harness
Does anyone make a complete harness. I've got a few gremlins and assume a whole new sort of "painless" set might be the answer. Car is a 76 with 84 3.2
Old 10-20-2017, 05:08 PM
Try timmy2 on here
Big job though ...
Old 10-20-2017, 05:31 PM
Peter Zimmermann's Avatar
Chris@YnZYesterdaysParts.com
Talk with Chris or the owner (Gene). Your car might be too new for them, but you can always ask.
Keep the Shiny Side UP!
Pete Z.
Old 10-20-2017, 05:35 PM
Thank you
Old 10-20-2017, 08:15 PM
I'll add another plug for timmy2. I've seen his work in person on other people's cars (I don't have any of it) and it's very nice. He can accommodate most any custom config.
Depending on the gremlins, a new harness may not fix things. Replacing a harness can also introduce new problems if not installed correctly. What are the current problems?
Old 10-20-2017, 08:29 PM
ROW '78 911 Targa
timmy2's Avatar
Many separate harnesses in these cars. What areas are giving you trouble?
And yes, very big job to replace all of them.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-20-2017, 09:33 PM
76 Harness
I have one. The rear of the harness was separated from the fuse panel and pulled through the tunnel.
The front is good but has cracks on one of the fuse holders.
Let me know if you want pics.
Cheers,
Louie
SHOPPING CART
Old 10-21-2017, 10:25 AM
Yes Please. My email is Tlgconstruct@gmail.com
After doing engine reseal. I'd has developed a stumble, brakec ights keep blowing fuse and given it's 40 yr old wiring with questionable butt connections. This splice n that splice. Seems like a fun winter project.
Old 10-22-2017, 04:17 AM
Recommend highly Timmy2. Dennis can put together whatever configuration you want. I have a 79 3.0 going in a 70. Lots of differences. No problem for Dennis. He has put together a number of harnesses for myself and a friend. Very easy to deal with.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 10-22-2017, 12:19 PM
