ASE Master Tech - 35 yrs
UPDATE - solved
since i live 2 hrs from any nearby guy with a same carrera & further don't know anybody who would let me plug my relay into his car .......... - spent an hour tracing thru the diagrams & pins-end-to-end with ohmmeter - figured out how it works - summary: bench testing involves activating the internal primary ign-on coil/relay & then using 9v battery test sets to check each other relay/coil output while the ign-on or ign-start is active i can provide my notes to others with the "problem" - there is also a thread showing the internals of the relay & another guy's attempted fix - google it i have a relay 911.618.153.00 (unknown functionality) from an '89, along with the blower (tested good), extracted from a wreck along with the engine i'm using in my header equipped 914-6; i have printed the diagrams from PET; the multi feeds & interconnects are puzzling to say the least without knowing which circuits override or are dependent on which others in actual operation just want to know if the relay is OK so i can sell it, since i'm not needing the blower this question is inspired by recent wtb post WTB: Blower Motor Relay for 3.2
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Relay.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I haven't seen anything but don't take my word for it.
I think you'll have to plug it in and see if everything autoheat related works. (and now I see Gerry's post) It's really more of a controller with a dip chip, some discretes, a reed switch and 2 relays. I did a quick look and only found posts related to footwell blower issues that implicated this controller, along with a work-around. But I didn't see a full-up write-up on bench testing. One could open it up, check for burn marks, and test the relays and reed switch maybe, but I don't see a board schematic other than an overall functional block diagram needed to go full comprehensive on it. There's 12 pins at the interface, so you'd have to check most of them simultaneously, as well as furnish a tach signal (!?) according to the car schematic. These aren't cheap so I agree its worth something if operational.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
[QUOTE=larrym;9592278]UPDATE - solved
I have my relay out and am wondering if you can tell me how to test it. My blower motor works when I supply 12v to it. I prefer not to buy a new relay if it is not the problem..... this is a 3.2 carrera heat blower relay 911 618 153 00 Is there a way for me to check it ? thanks
1988 911 Coupe Granite Green "Frogger" 1966 912R Coupe Stone Grey outlaw -"'Tilda" 1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter" 1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio) 1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001 |
Vintage Owner
These schematics may help. Energizing the relays and checking continuity may help, though I had heard that bypassing the reed switch is a workaround as that's a known failure point in the controller.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Vintage Owner
This is a corrected diagram that includes a jumper configuration that will not have the FW blowers run all the time. The note about the "engine blower removed or disconnected" is optional. The jumper works to run the FW blowers with or without an engine blower installed. If you keep the engine blower in the system, the reed switch feed should be cut as indicated. As the OP indicated you can check the individual relays with a 9v battery. But the only way to really check the reed switch operation is with a motor connected which is best done in a car. The reed switch needs current in the coil around it to operate, and that current comes from an operating engine blower motor. As for checking the IC chip on the circuit board...sorry, I got nothing
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 06-09-2017 at 11:04 AM.. |
Thank you guys...it is the relay. Specifically the engine compartment blower coil. Thanks so much!
