New User
The Canary Files: Rear view mirror mounting. (Hello!)
My old stick on the windshield rear view mirror has seen it's last days (glass has failed around the edges and it wobbles around). I like the look of the older shiny chrome mirrors so my lovely wife bought me one (she is a keeper!). What would be the best way to:
A: Remove the old "been stuck there for 48 years" mirror without cracking my windshield? B: Attaching the new shiny mirror to the metal lip without destroying my headliner??! I have a few ideas but those usually end in failure, much swearing and another much larger project to fix the failure. Any suggestions before the blowtorch comes out would be appreciated. Cheers. -Kav. ![]() ![]() |
3 restos WIP = psycho
I've been thinking hard about backdating my mirror. I say do it!
Sent from my Nexus 6P using Tapatalk
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Spiderman
I think all you have to do it drill two pilot holes and screw it on. I have a little 12 vdc to 5 vdc adapter mounted in the same place to power my dash camera. Just use short screws right through the vinyl and it will look fine. You can feel the metal easily. Just check that the visors still work OK for you. Blowtorch ?? Not sure best way to remove the glued on button, maybe stop by a glass shop to ask or better, get a new windshield. If its 30 years old it can't be in decent shape. Windshields are like motor oil, need periodic replacement.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Goo b gone and a razor.
2001 986 S |
A member here, rswannabe, installed a chrome SWB mirror recently. You could contact him and ask him how he did it. He's very helpful and does awesome work. You can see his results in this post:
My ST hot rod goes under the knife
Michel 1970 911T |
New User
Thanks I sent a message. I imagine he had the headliner out before doing the mirror install. I was thinking of using M5 rivet nuts? Give the M5 machine screw something solid to mount to? Thoughts? -Kav ![]() |
I think you could just drill and tap 3 holes; drilling the smallest holes possible to remove less material. Using rivnuts requires bigger holes. Maybe sticking tape to the headliner before drilling through it would give it more strength and keep it clean.
Please let us know what Brooke (rswannabe) replies - I've been thinking about doing this for a while also!
Michel 1970 911T |
New User
Sorry for the late reply, been out on a much earned vacation! Yes Brooke replied and I did the same, drilled three small holes and used short self tapping M5 screws into the holes. Mirror is solid and looks great! Cheers. -Kav. |
