Wer bremst verliert
Voltage fluctuations - Megasquirt and Lipo battery
I am finishing up a megasquirt installation on a 3l and am seeing weird voltage fluctuations in my logs. I am working with a tuner remotely and he noticed this before me. I am not sure if it is effecting the MS corrections but in any case it seems something that should be corrected?
I am using a batterytender LiPo battery, and the megasquirt is grounded directly to the battery. It was grounded through the chassis previously but this change did not fix the issue. ![]() Here is a log of a cold warmup. I have circled the voltage fluctuations in a white oval. Voltage swings from 13.8 to 12.4 and back again continuously. The alternator is a newish Valeo with internal regulator. It has maybe 5,000 miles on it without issue. I wonder if the lightweight battery doesnt act like a voltage buffer, I thought I heard normally batteries also serve to level out voltage fluctuations. Or a bad altertator regulator? Something else? Appreciate any help, John
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Fleabit peanut monkey
V-reg at first blush.
1981 911SC Targa |
Optimal battery max float voltage is 13.8 with max charge voltage being 14.2
The cycling between 12.4 and 13.8 is about the same range as a voltage regulator diode duty cycle.
1980 911 - Metzger 3.6L 2016 Cayman S |
Start with the basics...
Check grounds., clean and tighten If still having issues, have alternator voltage check with another O'Scope to see if the issue really is with the alternator - regulator. Also, if its the battery, swap with another battery. Just my $0.015 worth...
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
Wer bremst verliert
Thanks guys. Let me drill down on these....firstly, is that fluctuation abnormal and a problem?
Its an internally regulated alternator, so a pain to switch out. Hopefully something else but you could be right.I have a spare car I can switch it in but hoping not to have to do that. Quote:
~13.5v is what I saw in my logs in the car before rebuild. My Adaptronic log showed a solid 13.4-13.5 when running. Quote:
What type of wire did you use?
A lot of the Auto wire now is aluminum with copper Clad... junk IMHO for 911s I like marine grade copper wire that has been tinned
Wer bremst verliert
Like this ![]()
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy Last edited by JohnJL; 05-28-2017 at 06:14 AM.. |
Interesting!
Where do you measure your voltage? Sure its not interference from the engine bay (CDI ect.)? I would probably try the easy way out and simply install a capacitor for 2 bucks...... |
Platinum Member
Megasquirt in back (by engine) battery in front. You may be measuring noise and voltage drop in the cables. Is the tuner you are working with used to 911 or is his data based on front engine cars, where the megasquirt is likely connected with a very short cable to the battery?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Here is a quote from the Megamanual on grounding your sensors. They should all go to the same place (engine block) not the battery.
"The main grounds from pins #8, 9, 10, 11,& 18 go to one spot on the engine block. Do not ground them at physically separated locations, and do not use a single fat wire for this. Instead run separate wires from the pins all the way to the ground spot. Pin #19 is the sensor ground. If you have two wire CLT and IAT sensors, their grounds (and the TPS ground) should run back to the DB37's pin #19 to reduce the potential for noise in the sensor signals."
72 2.7 Driven! |
Wer bremst verliert
THe voltage measurement is as observed by Megasquirt. It internally logs voltage which is what is fluctuating in the log I posted at the top.
Wer bremst verliert
Wer bremst verliert
Then I switched in a standard lead-acid battery...no change in the voltage fluctuations. Then I switched in another fan/alternator assembly...no change in the voltage fluctuations... Anyone see strange voltage fluctuations on megasquirt? I seem to have eliminated the battery and the alternator as sources of the voltage swings. BTW this whole time my fluke multimeter shows a solid 13.6v while running. Its only megasquirt logs that show that weirf voltage swinging.
Wer bremst verliert
Got a part number?
JohnJL: I use a 4700 uOhm capacitor from a 944 electronic ignition system. Don't know the PN tho'. It is wired from the MS's power line to engine ground.
Oops -- 4700 uF (micro Farads), not uOhms. Last edited by cmonref; 06-03-2017 at 07:07 PM.. |
Wer bremst verliert
Hi all,
I switched in another alternator/fan and another battery. Can I ask again from someone who has a high-speed logger or o'scope if that fluctuation from 12.5 to 13.9 is normal? cmonref, did you wind up with that solution tracking down a problem? Why did you put that in? THanks
Oops -- 4700 uFarads, not uOhms. Sorry. Last edited by cmonref; 06-03-2017 at 07:06 PM.. |
ROW '78 911 Targa
Bitz kit EFI instructions suggest using a 4700uf 35 volt D.C. Electrolytic capacitor on all switched power going to the ECU and Wideband 02 if using one.
Would anybody be willing to throw in a picture or diagram of the capacitor installs? ... just connect in-line?
thanks, |
I had a slight oscillating idle and some uneven running below 3000rpm after instaling the Bitz EFI kit. This was almost completely eliminated after installing the 4700UF capacitor to the wideband sensor as recommended.
