I got BRAID 15X8's and 10's for ST Flares, not fitting , what next?
Got some wonderful ST rear Flares from Europe, these are the ones from Germany or Poland that AASE and Stuttgart Classica are selling, read a million threads about ST wheel sizes, got my Braid USA 15x8, 15x10 RSR finish wheels,gorgeous by the way, standard Fuchs offsets... Got My TB-15 tires, lovely.... Now my metal work man is telling me he would have to add 1-2" to thee flares to make this fit--
Everything everywhere says you can run 10's on the ST rear, I know all the ST flares were various sizes, and not really standardized....
I like the smaller non RSR, non Turbo look of these Flares, should i add metal or get 9's? Different offset?
Old 06-28-2017, 11:42 PM
3 restos WIP = psycho
kenikh's Avatar
My recollection is that ST rear flares are 9", which aligns with what you're seeing. With the right backspacing, I'm sure 10s will fit...just not your 10s. I'd call Braid.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-29-2017, 12:37 AM
Bill Verburg's Avatar
flair descriptions are a bit nebulous, but generally
SC/Carrera = 9"
ST =10"
930/RSR = 11"
'74RSR = 13"
It doesn't look like a 1- 2" mismatch to me but pics can be deceiving
Seems like you need a wheel w/ less front envelope
according to the Braid web site the 10x15 has an ET -15, if so
front envelope of the wheel is 6.09"
back envelope is 4.91"
tire envelope will depend on the size and idiosyncratic tire profile
max front space for an SC/Carrera is pretty well documented @4.5" w/ max back space 6"
assuming the ST is ~1" more roomy this allows a max front of ~5.5", so it looks like you need either ~ .5 to .6 more fender or the same amount less front space, a 10x15 ET 0 would give you 5.5" front space/5.5" rear space
The above is all approximate and depends on details
Bill Verburg
Old 06-29-2017, 05:39 AM
thanks Bill, great info there, I guess since I love the look of these 10's and the TB15's I'm going to just add an inch of fresh metal to the quarter, keeping the ST smooth round over, but fitting these Braids..
I guess the lesson here is go with 9's in the rear for your ST builds if you are using the current ST rear flare offerings.....
Old 06-29-2017, 06:04 PM
For reference, my car has likely the same Euro-made ST flares you have. Im running the Group4 8s & 9s. 9" rears are ET-3 and I added 1/4" spacer, running -2deg camber.
There's plenty of room for a 10" rear given the right offset/backspace without widening the flare.
Marc Zurlinden
zurlindengruppe.com
Old 06-29-2017, 06:14 PM
cnielsen's Avatar
Completely depends on offset.
I have 10" wide Fuchs on the rear of my factory ST flares. They fit similar to yours prior to the alignment but then tucked in nicely after the alignment.
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 06-29-2017, 08:48 PM
Your rear setup 9 ET-3 +.25 has a net ET3.35 w/ a front space of 4.87"
Bill Verburg
Old 06-30-2017, 04:19 AM
great color! looks much more gunmetal that then the standard warm gold of the group 4 palette...
whats the offset of your fronts?
Old 06-30-2017, 08:21 AM
Open Highway Productions
Mad Max's Avatar
Wow! That is all...
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 06-30-2017, 10:27 AM
Cory M's Avatar
metalracer and cnielsen I love both of your cars, so nice.
Old 06-30-2017, 04:04 PM
