-   -   Replacing a drive shaft (http://forums.pelicanparts.com/porsche-911-technical-forum/961728-replacing-drive-shaft.html)
kohho 06-29-2017 07:45 AM
A torn CV boot and some water got in there damaging the spline on the drive shaft so I'm replacing the drive shaft on that side. Just wondering if there is any safety or performance issues if I replace only one side leaving me with one drive shaft original and the other new (e.g. different weight).
Thanks!
http://forums.pelicanparts.com/uploa...1498746961.jpg
T77911S 06-29-2017 07:48 AM
no
Drymartiniwi 06-29-2017 08:32 AM
I had the same issue so I just replaced both. If one side went bad the other is not far behind
kohho 06-29-2017 02:22 PM
Originally Posted by T77911S (Post 9644060)
no
Direct and to the point :) thanks!
kohho 06-29-2017 02:26 PM
I'm also having the calipers restored plus a few other small items so I need to keep the cost down a bit where I can ( in case the wife sees the Visa bill) 🙂
Jdub 06-29-2017 02:58 PM
I am just South of you and can give you a pair of axles for cost of shipping. To be clear these are only a pair of shafts. PM me if interested.
gtc 06-29-2017 03:46 PM
New boots, gaskets, bolts and grease for the other side is pretty cheap. Repacking the CVs before they go bad is dirty work but cheap insurance.
Drymartiniwi 06-29-2017 03:52 PM
Originally Posted by kohho (Post 9644617)
I'm also having the calipers restored plus a few other small items so I need to keep the cost down a bit where I can ( in case the wife sees the Visa bill) [emoji846]
If she sees it just tell her your just trying to keep her safe. Calipers are not hard to rebuild. Just take your time and reference you Bentley manual to make sure and you also have a lot of backup on the forum.
kohho 06-29-2017 07:08 PM
True enough - this would definitely be a good time to do it. Had a look at your car, looks great, love those sport seats!
T77911S 06-30-2017 03:41 AM
check the rubber lines. if they look cracked or dried out replace them. they DO go bad
OldSpool87 06-30-2017 04:11 AM
If you're already in CV grease mayhem you may as well inspect the other side. Be prepared to find pitting by having one or two new CVs on hand. I found one of mine damaged.
https://uploads.tapatalk-cdn.com/201...6ef03565ee.jpg
https://uploads.tapatalk-cdn.com/201...2914571054.jpg
If they all look good you could swap sides to even out wear. Definitely read the ultimate CV thread http://forums.pelicanparts.com/porsche-911-technical-forum/222537-reconstructing-constant-velocity-cv-joints.html
Good luck
Sent from my iPhone using Tapatalk Pro
sugarwood 06-30-2017 07:50 AM
Does that nick photographed above have any real impact?
A large metal ball bearing slides through that big groove,
so it seems like a tiny nick would be totally moot.
The first photo nick seems like it would have no impact, but the 2nd photo looks like a bigger chunk.
The only scenario I can think of would be the nick being so big that the ball no longer rolls smoothly over the "pothole"
Then maybe you'd hear a sound? Or it would start to wear the ball away?
KTL 06-30-2017 08:27 AM
That nick is the sign of a metal casting flaw because you can see some depth in it. The wear around the nick will progress sort of quickly because the hardening in and around the nick has been compromised.
Also the picture showing the nick is an example of a CV that has been "flipped" or run in both directions on the car. In other words the axle was run on one side of the car and then removed and run in the other direction, most likely by installing it on the other side of the car. The telltale sign is the wear pattern on both sides of the race. An axle that has been run in only one direction will have the wear pattern on just one side.
It's usually the race that wears and the balls look fine. The balls are hard chrome coated and most often look just fine even if the race shows some major wear or pitting. That said, I just did the re-grease and re-boot job on a set of 2001 dated Carrera 108mm CV axles and the races look fine with just some typical wear. But one CV had the set of all six balls were scuffed (could feel the roughness with a fingernail) in various locations around the periphery. So I sourced some used balls from Pelican member Tom Butler to "rebuild" the axles as best I could.
Walt Fricke 07-01-2017 05:47 PM
I agree that inspecting the other side is a good idea. But your problem was rust in the splines due to a boot cracked probably for a long time. Thrifty as I am, I'd replace that shaft. But absent damage to the other shaft, no need to replace it. They do break, but can also last a long long time. I've got the original '77 splines in my updated to SC spec car, and they've yet to break despite heavy DE and racing. Lots of CVs changed (if you can feel an imperfection in a race, replace, and that is a big hole through the case hardening), but never an axle.
Jdub 07-17-2017 10:06 AM
Carl - PM'd you but want to update here that two very nice axles are on the way. Your patience will be rewarded!
Did not lose anything in the fires here in the NW btw but they certainly did distract us for a bit!
kohho 07-19-2017 09:52 AM
Patience WAS rewarded - thanks Jdub!
absolutely perfect! Can't wait to install - I might even do a short video if I feel inspired. Thanks again Jdub, I owe you one! PM me the shipping cost and I'll reimburse
http://forums.pelicanparts.com/uploa...1500482977.jpg
theiceman 07-19-2017 10:26 AM
http://forums.pelicanparts.com/uploa...1500485006.jpg
once it starts get them out, coz the metal went somewhere and will just start chewing up even more.
bugstrider 08-27-2017 10:33 PM
I am in the middle of this project. All races show significant wear and damage. Multiple divots on the tracks, visible and when running your finger in the grooves of the outer race. All units are dated with two manufactured in "77" and two in "84".
https://uploads.tapatalk-cdn.com/201...4bb03e209a.jpg
https://uploads.tapatalk-cdn.com/201...28c23d1a8f.jpg
https://uploads.tapatalk-cdn.com/201...1b29d8466a.jpg
Spider gears also show divots and gouges
Found this little nugget when cleaning the shafts. Surface rust and pitting where the boot is suppose to seal to the shaft.
https://uploads.tapatalk-cdn.com/201...bc15f9958c.jpg
https://uploads.tapatalk-cdn.com/201...60d54c1f0f.jpg
If I clean this area up and seal it via paint or powder coating, should I be good to go?
Cheers
KTL 08-28-2017 11:49 AM
Yep that shaft will seal fine I think
bugstrider 09-18-2017 12:13 PM
Thanks KTL,
Cleaned and coated.
https://uploads.tapatalk-cdn.com/201...ecf98f6872.jpg
https://uploads.tapatalk-cdn.com/201...23e2b65e91.jpg
Here is another question regarding the lock washers. I have sourced some washers that are a little different dimensionally than the factory ones. My question is that will the size make any difference regarding the bolts.
Here are the differences-
OEM thickness
https://uploads.tapatalk-cdn.com/201...5581b8a2db.jpg
New
https://uploads.tapatalk-cdn.com/201...c593d72118.jpg
OEM OD
https://uploads.tapatalk-cdn.com/201...9120c555a2.jpg
New OD
https://uploads.tapatalk-cdn.com/201...7a7225d465.jpg
New ID
https://uploads.tapatalk-cdn.com/201...93dd799c26.jpg
OEM ID
https://uploads.tapatalk-cdn.com/201...f0ca60e0ce.jpg
OEM
https://uploads.tapatalk-cdn.com/201...37795193c6.jpg
NEW
https://uploads.tapatalk-cdn.com/201...95ee28cbd9.jpg
Thoughts?
