I added a little negative camber along with corner balancing and it handles so much better.
73T Maus 75S Targa 86 Carrera SOLD ------------ |
Did anyone mention Lemforder Turbo tierods? They are a must. Do them at the same time you install Elephant rubber bushings, stiffer T-bars, and a rack spacer. (I went to 21mm bars in the front on my cabriolet and am ready for 22mm)
Under the radar
If you want to take it to the next level, larger torsion bars, as mentioned, are a common upgrade. 21 and 26mm is a common size for upgrading for Targas. Not overly stiff, but firmer than stock.
Something else to consider is weight reduction. Less weight is a cost effective way to increase performance. Lots of threads on reducing weight on these cars.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 07-05-2017 at 07:50 AM.. |
Thank you very much.
Thread Tools | |
Rate This Thread | |
