SoCal911SC's Avatar
New H4 headlights just arrived_question
Just received my H4's today and was wondering if there's a seal or gasket I need to purchase separately or if these just mount in?
I've read some horror stories of units falling out from the single screw that holds them in and wondering how others have secured them from falling out. Thanks!
2014 Panamera Turbo Executive
1982 911SC Targa - Guards Red
1983 DeLorean (Sold)
2001 996TT - Lapis Blue (Sold)
1995 993 C2 - Grand Prix White (RIP)
Old 09-25-2014, 08:33 PM
Go-Kart Mozart
JAR0023's Avatar
Yep, there is a gasket that sits between the headlamp assembly and the fender. Gasket will be seamed and flat on one side shaped on the other. Shaped side toward the fender. Seam at the bottom. You'll have to stretch the gasket on. Start at the top and work down stretching as you go. You don't won't too much pressure on the seam or the gasket will separate at the seam. Hook the lamp assembly at the top, compress gasket as you press in at bottom of lamp, then insert screw while there is no pressure on it. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 09-25-2014, 09:18 PM
Bye, Bye.
Scooter's Avatar
Yes, you need the headlight rubber seal. See: Porsche 911 (1974-1989) - Lights and Lenses - Page 5
Elvis has left the building.
Old 09-25-2014, 09:19 PM
SoCal911SC's Avatar
Good info. Do I stretch the gasket/seal onto the assembly or onto the fender?
Old 09-25-2014, 09:27 PM
porwolf's Avatar
Yes, seals (Pelican Parts) go between the Euro H4 headlights and the fenders. There is some skill involved to get the seals in the right place and secure them. Then there is the question on how to securely mount the H4's themselves. It should not be a big problem if the fenders are almost new and not bent in some way by repair jobs. And last, there should be relays (also Pelican Parts) installed with the H4 headlights to prevent heavy currents going through the headlight and dimmer switches.
Lots of threads and postings here:
A question about headlights
City lights
Euro parking lights
Feeler: New Bosch Euro H4 Headlights - Trim Rings NOT Included
H4 euro style install frustration
H4 fitting question
H4 Install...is it REALLY that easy???
H4 Trim Rings don't Fit
H4's keep popping off. What can I do?
Headlight Install
Headlight seal
Help! H4 will not close down with new seal (with pics)
Upgrading To H4 - What To Do With "City Light"?
After all those posts, I would not be too anxious about the safe mounting of Euro H4s. I have done it a year ago on my all original '79SC and it was not a big problem. I found out that the most important thing is to make sure that the M5 light mounting tab is bent sufficiently downwards. So much so that it is somewhat difficult to engage the Phillips screw driver. The screw driver should touch the bumper and still not engage straight with the mounting screw. Only then do you get enough downward pressure on the head lights to securely engage with the holding tab on top of the light buckets.
Good luck!!
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-25-2014, 09:28 PM
porwolf's Avatar
You stretch it onto the fender. Using silicone grease helps to slide the H4 assembly on.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-25-2014, 09:32 PM
Do it
While the weather is still warm, so you can lay the gasket out in the sun to make it easier to work with!
Old 09-25-2014, 10:26 PM
Regis turd ab user
Read post #19 regarding proper fitting gaskets. Also if your gasket does have a visible seam place it on the bottom, if it separates it will allow water out. I agree with light silicone type lube as well, it's actually good on all of the light lens gaskets.
Euro H4 conversion a costly lesson
Old 09-26-2014, 04:44 AM
Can anyone confirm if they are HANDED? my left one doesn't seem to line up good.
Can't see any difference in part numbers and most advertise as left or right so thinking not.
Thanks Brent
Brent
Christchurch, New Zealand.
Project: 1973 RSR Clone build http://forums.pelicanparts.com/porsche-911-technical-forum/576125-nz-73-rsr-clone-build.html
Old 07-15-2017, 08:45 PM
911T '72
DeRRis's Avatar
They are not HANDED. Left and right are the same.
Dennis
Good drivers have dead flies on the side windows. (Walter Röhrl)
Old 07-16-2017, 01:43 AM
Thanks Dennis for the confirmation.
Brent
Old 07-16-2017, 04:28 AM
wayne robson's Avatar
H4 left and Right
Hi Brent , thought i had better let you know,as DeRRis says ,yes that is correct
there is no left and right,same on both sides,but for left hand drive cars
the lens have the angled side of lens on right side,--part number --1305-614-005
on right hand drive cars that is NewZealand,-Australia-etc the angled side of lens
is the left side part number--1305-614-006, looking front on,.
ask me how i know,Born in NZ, lived in US 10 years, now live in Ausy.
Brent if you have the 005 lens for left hand, the authority safety cert guys would
not notice that im sure, see a pair i have owned for years, regards.
Old 07-16-2017, 05:40 AM
I carefully bent the metal edge around the headlamp opening out just a little and added a lanyard just in case. I also ran ignition power to the running light inside the headlamp so when the key is on the running lights come on.
Old 07-16-2017, 06:27 AM
