Very ingenious.
Kudos! I've been very impressed with the quality of Rustoleum paint. |
No updates from those who did this a while ago??? It would be appreciated.
I was studying this again as well as checking online for paints. The Krylon paint illustrated is not "dull" but 'bright". I see what appears to be the same paint online and am hoping someone can confirm this is the same 1403. I also found a Krylon Dull Aluminum #1403 which looks quite different.
I'm impressed with the work put into this as well as the results. I mostly want to use the correct product. |
Looks great!
I had a cracked rim and a partial can of 2k paint so I thought I would give it a try.
http://forums.pelicanparts.com/uploa...1598715995.jpg http://forums.pelicanparts.com/uploa...1598715995.jpg |
So far so good. Even though I used the 3M duct tape I still had some leakage. If I do this again I will get a tub big enough for my wheel and I will put the tub and add water.
http://forums.pelicanparts.com/uploa...1598811028.jpg http://forums.pelicanparts.com/uploa...1598811028.jpg |
The paint was not quite dry but I was paranoid about my water leaking out so using a tooth pick I removed most of the silver paint that was sitting on the surface of the water.
http://forums.pelicanparts.com/uploa...1598811710.jpg |
Overall I'm very happy with the results and the effort that I put it to this rim. For my good rims I will have them powder coated black (everything) then apply to Eastwood 2K silver paint.
http://forums.pelicanparts.com/uploa...1598819995.jpg |
FYI,
My mistake was NOT covering up the lug holes. Once you tightened the lugs, the paint will crack which may extend beyond the hole!! Serge |
Nice info and thanks!
I am getting ready to try this. I am including photos of the paint I purchased yesterday. Can graphics are different but this is the only 1403 Dull Aluminum I could find. Finally settled on O' Reilly's about 6$ a can. alwaysflat6' hope this helps. http://forums.pelicanparts.com/uploa...1611435982.jpg http://forums.pelicanparts.com/uploa...1611435982.jpg |
There's a real issue (or detail) about preserving the paint. How to protect it so it lasts years (?) before redoing the process?
Sherwood |
All you can do is buy the best paint available. That is why I chose the 2K paint at $25 per can
Subscribed and awesome!
Agree with Harpo do this is a tub instead of taping the backsides. Easier and no mess if your taping leaks during the paint drying process.
https://www.amazon.com/Eastwood-14148Z-Spray-Paint/dp/B0743FCN5L/ref=sr_1_1?dchild=1&keywords=eastwood+2k+spray+pai nt%2C+matte+black&qid=1611453970&sr=8-1 Sherwood |
David |
Is there anyone that has done this and can report back on longevity? I am only curious about painting the petals and wear and tear of washing, etc...
I am going to go on ahead with the process and will report how things are holding up - i'll try and log in here to give updates. |
I deliberately left my wheel outside since August and still looks awesome
| All times are GMT -8. The time now is 10:29 AM. |
