keitho64's Avatar
Question Oil Thermostat o-ring replacement question
I attempted to replace the o-ring on my oil thermostat last night. I removed the two 10mm nuts from the top but it did not want to come out. Is there another bolt holding the thermostat in that I am missing, or is it difficult to pull the thermostat out?
Before I take the brute force approach, I thought I would ask here. I could not find anything in the archives on this topic and according to my manual I should only remove the two nuts. I appreciate any ideas.
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 02-07-2003, 05:10 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
when I replaced mine it didn't want to come up so I pryed it up with a short piece of wood. There's a "tab" where you can place something underneath and not hit the seal at all. After I got it started it was easy to pull out.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-07-2003, 05:36 AM
Early_S_Man's Avatar
Porsche Crest
A couple of sturdy bottle cap openers under the sides of the housing should free it up.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-07-2003, 05:37 AM
Rick Lee's Avatar
While I wouldn't want to pry too hard, I assume you're replacing the O-ring. So don't worry about ruining that part. I used a very thin flat head screwdriver.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 02-07-2003, 06:03 AM
Irrationally exuberant
ChrisBennet's Avatar
A right angle/offset screwdriver is great for prying in places like that. Sears has them for $2 (link to Sears Ad)
-Chris
Old 02-07-2003, 06:19 AM
keitho64's Avatar
Thanks for all of the ideas. I figured that it was just stuck but I was reluctant to pry to hard unitl I asked.
Chris, I have one of the offset screwdrivers and will try that tonight.
Keitho64
05 GTO
00 911 C2
64 Corvair
Old 02-07-2003, 06:24 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Keith,
Might want to consider putiing some o-ring lube/sealant on the new o-ring to extend its life.
Popular choice is Dow Corning 111 or 112 Silicone Compound. 112 has a higher temp. rating and would probably be the way to go.
Dow 111 pdf Data Sheet
Kevin L
'86 Carrera "Larry"
Old 02-07-2003, 06:47 AM
